Couple of new engine parts!!
Old Dec 4, 2004 | 02:00 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
Default Couple of new engine parts!!
Just letting everyone know that there is a new LS1 specific connecting rod available!!
Designed and produced with engieering and finishing advancements, CompStar connecting rods have what it takes to make your enginebuild trouble free and your finished product reliable. Produced from heat treated and stress rerelived 4340 material, CompStar rods are fully machined with a shot blasted stress riser free surface. Every detail of this highly stressed component has been carefully analyzed to maximize repeatabilty and dependability. See for yourself why CompStar can inprove your bottom line and reputation.
  • retorque processing ensures full burnished and seated threads and bolt spot face areas: resulting in consistent assembly sizing
  • Stroker clearance that is designed into each rod
  • ARP 2000 bolts carefully positioned fastener supporting gussets
  • Large outbaord mating face contact area
  • Fully detailed and prepped parting lines and bearing tab pockets
  • Consistantly fianl sized within a .0003 tolerance on the advanced Sunnen Cross grinding system
  • Weight matched to within 2 grams
  • Horsepower range, SB and LS1 = 700hp
  • Typical weights: 6.125 LS1 rod = 619 grams
  • Also available in custom order sizes
We now have these available and also on sale for anyone who is interested!! See our thread in the Sponsor specials section.
Second item that Calies is now offering is the LS1 Big Bore Wet Sleeve blocks.
  • Mian caps installed with ARP studs
  • Main bearing housing line bored after sleeve installation
  • Deck surfaces trued and finished to accommodate MLS gaskets
  • CMM verification of bank angle, deck height, and bore centerline
  • Billet main caps
  • ARP head studs
  • Cylinder diameters bored and finished to your spec
These blocks will also be on sale along with the CompStar connecting rods. See our thread in the Sponsor special section for more details.
https://ls1tech.com/forums/sponsor-sales-specials/245923-new-ls1-specific-connecting-rods-sale-ape.html
https://ls1tech.com/forums/sponsor-sales-specials/245927-callies-compstar-wet-sleeve-blocks-sale-ape.html
If you have any questions, please feel free to ask.
Thanks
Old Dec 5, 2004 | 07:52 AM
Cstraub's Avatar
Chris,
You have e-mail, I need a response.
Chris
Old Dec 5, 2004 | 10:58 AM
Ed Curtis's Avatar
Question
Isn't this just another Chinese H beam rod???
AKA Eagle rebadged?
Ed
Old Dec 5, 2004 | 12:10 PM
Reckless's Avatar
Super Moderator
I doubt a shop with connections in the Detroit area would push off-shore rods. I am guessing Chris is hooked up with a local forger.
Old Dec 5, 2004 | 12:29 PM
Ed Curtis's Avatar
Cool
"Engineered, finished and checked by Callies Performance Products"
Nowhere does it say "manufactured" by Callies...
Sounds imported to me...
Nice picture in Circle Track magazine, page 42... Check it out.
Ed
Old Dec 5, 2004 | 05:10 PM
Reckless's Avatar
Super Moderator
Anything is possible Ed, but there are plenty of forging sources in the Motor City area.
Old Dec 6, 2004 | 08:35 AM
Edc is right! They are a offshore forging. They are machined by Callies. Almost all of your forgings today are being done in the far east. This is not a rebadgeed Eagle, these rods are of a higher qaulity than the Eagles.
Old Dec 6, 2004 | 12:01 PM
Reckless's Avatar
Super Moderator
Don't let Kurt hear you are selling off-shore parts
