4 Degrees advance ?
I currently have the c.c.212/218 cam that comes with 4 degrees built in advance. I know that having such brings the v.e. on earlier but in tuning after the install I was capable and needing to add up to 8 degrees all the way to the 4000 rpm mark with no k.r. Also somewhat comparing another forum member has somewhat of a more radical cam (more duration,lift,overlap) and runs very well with stock programming. Any input
or enlightening as to why I was capable of adding this amount of timing(using ls1 edit)??? I was hoping I would find it in the cam discussion and /or if I did
it went way over my head.
I have added a bit of timing at idle and off idle for my TR224. But only about 3 deg. Hence I am 27-32 degrees idle and off idle.
Perry
Thanks Perry. It kust strikes me odd to add so much advance to such a mild cam and from what I've heard the ls1 head does not usually like so much advance. Anymore input??
What are your advance numbers (particularly at low load .26-.40 gm/s and low rpm)?
If you are much over 30-32 that is high but won't hurt anything if you aren't getting KR. I had no problem with KR at low rpm but low load, low rpm cruise (.4-.6 gm/s and 1600-2500, I had knock problems) So no harm no foul.
Perry
Perry
