Top 5 LS1 stage2 heads
<strong> Here's my Absolute Speed Stage II Set up:
LS1 Castings ('98)
209cc Int Runners
milled for 10.8:1 comp
Manley Pro Flow 2.02/1.578 valves
Flow #'s, Exh #'s without a flow tube:
Lift Int Exh
200 159 107
300 212 146
400 267 193
450 284 203
500 296 217
550 301 220
600 307 223
Dyno #'s are below
Thanks, John. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Who flowed those heads for you? Most likely the person you bought them from. If those heads flowed 307 they would support about 600-620 hp with a good solid roller. A guy bought a set of heads that supposedly flowed 340 (LS6) and on our bench they flowed 300. Not saying your heads don't flow that, but just know that you should be able to make a little more power with that much flow IMO.
Nobody mentioned SAM heads, but since we don't sell them and just run em I guess that's why. Our orange car heads flow 340 and it makes 692 hp.
It will be interesting when Tomtheroofer[TTR]gets his flywheel HP and then dyno's thru auto for a comparo.
SRP, TEA, MTI, GTP, & LPE
These are heads I would consider with additional research and seeing more proven results.
LG Motorsports
Cartek
<strong> 695hp even if it si at the crank it might still put down 600 to the wheels.Even if it is 400+ cubes that is alot of power.
SAM. How high are you turnin that thing ?7500? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It actually turns a little over 8,000. It has excellent heads and valvetrain. SS valves and Jesel. Jud just ain't scared to turn it it up. Good motors make power past peak, it's a sign of good heads.
<strong> The dyno graph posted by mrb00formula is not accurate. Where did that come from?? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The dyno I posted in this thread is accurate!
The the first dyno was not SAE, this one is.
FYI- the difference between "Actual" and "SAE" was nominal.. like maybe 3-5hp max.
LS1 Castings ('98)
209cc Int Runners
Lift Int Exh
200 159 107
300 212 146
400 267 193
450 284 203
500 296 217
550 301 220
600 307 223
Dyno #'s
404.0 RWHP
398.3 RWTQ
Thanks, John. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Absolute Speed
Stage 2 Porting
STAGE 2
LIFT- INT- EX
200- 151- 109
300- 213- 149
400- 271- 192
450- 280- 204
500- 292- 219
550- 297- 222
600- 303- 225
If I had long-tubes, no cats, and the slightly larger Thunder 224 cam then I would presume I would have gotten about 5-7 more HP and maybe 10-15 in the TQ dept. However.. both of our cars will not be slouches on the track, thanks to Jay's Absolute Speed Heads! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Both John and I posted our numbers.. now lets see some of your dyno print-outs. Put up or shut-up, plain and simple. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The Orange car made 695HP more than likely to the flywheel not rear wheel, solid roller cam, definately not stock cubes or stock rotating assembly, bet it won't run on pump gas either. That isn't a good comparison. Put his heads on your engine and I bet it would make a huge hp increase. Put your heads on his current setup and I bet the hp won't go up that much...Come on be realistic here....
<strong> i have r.g.r st2heads.i'm not saying my heads are the best but i only paid $1,600 for them. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I paid ~$1300 for stage 2 heads which perform well. No regrets here! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SAM81:
FYI- the difference between "Actual" and "SAE" was nominal.. like maybe 3-5hp max. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It doesn't matter how you measure the hp. It could have said 1000 hp and I couldn't tell you otherwise. The graph does not accurately portray hp and tq at the correct level vs. rpm. Anyone who runs a dyno could tell you this.
