What makes a cam "lope?"
ok, im done having fun
It came out to be -9
Will my idle be like stock?
overlap Year Lift Duration LSA Timing
LS1
-31 97-99 .479/.472 207/199 117 113/121
-27.5 2000 .500/.500 209/198 115.5 112/119
-30.5 01-03 .479/.467 207/196 116 117/115
LS6
-24.5 2001 .535/.525 211/204 116 114/118
-24 02-03 .551/.555 218/204 117.5 115/120
So -4 (TR224) cam and your cam will still be much choppier than stock.
LS1
LS6
Those durations are listed backwards compared to what is usually seen. I'd just like to clarify this for anyone who might scroll upon this and think all of these are reverse split camshafts. So for example. Cam 1 (97-99) would more commonly be seen as: 199/207 .472/.479 on a 117lsa.
you can see the stock cam spec's off a cam doctor in the FAQ in my sig.
I did not actually look up this info I just got the specs off an other guy on the Internet.
The way they are listed is a bit confusing since that not the way most people list cam specs. The way they are shown all these cams look like reverse split cams. They are not. All the intake and exhaust specs are backwards and on top of that they are all the specs for the y-body’s not the f-body cars.
Here is a more accurate table and less confusing.
LS1 Y-Body’s (Corvettes)
-31 97-99 .472/.479 199/209 117
-27.5 2000 .500/.500 198/209 115.5
-30.5 01-03 .467/.479 196/207 116
LS6 Y-Body’s (Corvettes)
-24.5 2001 .525/.525 204/211 116
-24 02-03 .555/.551 204/218 117.5
LS1 F-Body’s (Camaro, Firebird)
-35.5 98-00 .500/.500 198/209 119.5
-30.5 01-02 .467/.479 196/207 116
whats the highest you can go to sound like jsut a full bolton car? i want the ultimate power on the ultimate sleeper for the time being and this info will help
Simply put, advancing a cam makes it more exhaust bias relative to TDC. Retarding a cam makes it more intake bias relative to TDC.
Just gotta get a new converter with a good tune and you're set.
