EVERYONE WITH LS1
Old Apr 16, 2003 | 03:17 PM
MSRP's Avatar
Default EVERYONE WITH LS1
DOES ALL THE LS1 HAVE A TICK TO THEM ARE IS IT JUST MINE. AND IS THIS NORMAL WHEN I GET ON IT AND IT HITS INBETWEEN 4000 AND 6200 IT HAS SORT OF A FAINT RATLE SOUND TO IT AND TAKE INTO AFFECT THAT IT ONLY HAS 24000 MILES, WHEN I TAKE IT TO THE DEALER THEY " OH THATS NORMAL " SO ANY COMENTS WOULD HELP
Old Apr 16, 2003 | 04:39 PM
DONAIMIAN's Avatar
Default Re: EVERYONE WITH LS1
What type of tranny is it connected to A4 or M6 <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Apr 16, 2003 | 04:44 PM
Cal's Avatar
Cal
The tick is normal though not all do it; mine doesn't. The rattle from 4000-6200 sounds like knock, you might want to check that out with Autotap or EFILive, not a good thing. If you have a M6 with aftermarket shifter you might hear a rattle at some rpms also.
Old Apr 17, 2003 | 01:12 PM
LS1LT1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Cal:
<strong>The rattle from 4000-6200 sounds like knock, you might want to check that out with Autotap or EFILive, not a good thing.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, be sure you're using only a good quality premium fuel if that's the case.
Do you have an aftermarket MAF, Hypertech or any other 'pocket tuner' type device installed?
Bad cats? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Apr 17, 2003 | 01:33 PM
SSCamaro99_3's Avatar
Mine has always ticked a little. No problems other than the crappy power window motors. Can I convert to manual windows?
Old Apr 17, 2003 | 04:08 PM
mike c.'s Avatar
i had a SLIGHT tick between idle and 2,000rpm's on my 01 only when cold.i did'nt notice it at all when car was worm. like cal said a-tap it,it could be afew things making it do that. goodluck to ya man.
Old Apr 23, 2003 | 02:15 PM
MSRP's Avatar
NO AFTERMARKET PARTS, JUST A HIGH FLOW AIR LID AND I PUT AMACO 93 IN IT ALL THE TIME. ALL THOUGH I JUST CHANGED THE OIL AND PUT REDLINE 10W40 AND IT STOPPED MOST OF THE NOISE, BUT OTHER THAN THAT IT DOES'NT MATTER IF IT IS COLD OR WARMED UP, THE SAME NOISES PLAY IN.
Old Apr 23, 2003 | 08:13 PM
Y2k Pewter TA's Avatar
Sorry guys but i know the answer 2 this riddle its ur pushrods. Thats a major effect on the LS1's and that is normal, they all do it cuz at around 5000 RPM they bent a little check it out all of my friends w/the LS's hv the same problem and the dealer lead tech checked it and it was a pushrod but thats ok its cuz we hv weak pushrods they are not chrome moly. Thats true when they are cold u can here it more cuz the engine is cold thats gonna be the effect so dont worry 2 much it will be alright. Oh yeah by the way we did use the autotao and got a diagnostic test at the dealer they were all ok.
Old Apr 23, 2003 | 08:17 PM
Another thing guys its hush hush from GM there is a recall the rockers in our cars if u change ur oil and see metal shavings in it then u qualify for brand new rockers even if ur out of warranty duh. But anyway check it out got the source from the lead tech at Mission Chevrolet hes a good friend lets just say i hv some new rockers in my TA. Just thought u might want 2 know. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
