Which Lifters For Trex Cam
I need some lifters anyone know someone with some that they may have forgot about. I have check all of the for sale sections and there is no one really selling any. The one guy that has some for an LS1 does not know a whole lot about the history of them so I am not going to get those I do not think....
Originally Posted by sevanseriesta
How long do you think it would take to check all of the pushrods
Ok, I have been told that there something special that you have to do to put the rockers back on is this true or not.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
make sure the pushrod is in the indentation on the rocker and torque it properly, if you want to feel better rotate the engine around with a socktet on the crank and recheck the rockers. its really extremely easy, just sounds complicated.
Allways set preload (torque rockers) at base circle of cam.
While rotating motor clockwise with long pull handle attached to the harmonic damper bolt. Adjust both intake and exhaust valve directly after each intake valve closes on compression stroke at TDC. After adjusting the number 1 cylinder move on to the next one using the firing order sequence. I forget what the firing order is for the LS1.
There are other easier ways of doing this, but I do not have the time to tell you.
the process you describing isnt used on ls1's, the old process of tdc on compression is like intake 1,4,6,7 and exhaust 1,5,6,8 or something like that but thats not how to do the ls1's
![Smile](https://ls1tech.com/forums/images/icons/icon7.gif)
Originally Posted by SMOKIN01TA
you do realize that the ls1 isnt like the old chevys and vortec motors, you dont have to be at TDC to do this you put them all back on and just torque each one to 22ftlbs. the lifters take care of the rest. theres none of that torque to snug and go another 3/4 turn stuff like the old small blocks.
#34
everything is good to go thanks again guys for all of your help......I may be asking a few more questions here in about a month on some things that I need to do to do my cam swap. I want to do that myself aswell. I am enjoing learning all of this new stuff and how to work on my car. So far I have put a ford 9" in my, car swaped from an auto to a m6, changed pushrods installed and removed a supercharger, pulled an engine from an LT1 put an engine back in an Lt1, Installed a 255 lph fuel pump (cheated though used the trap door methos) Now I am ready to install the cam and maybe later mess with the bottom end but who knows
