A few pics from my build
Specs on the build are: APE 382 shortblock, Callies crank, Eagle rods, Diamond pistons w/-7cc reliefs, TEA/AFR Stage 2.5 Judson heads w/nitrous exaust port milled .024 to 62cc's, FAST 90/90 port matched by me, Comp XE-R 244/248 .612/.615 111+2 spec'd by me, Morel lifters, ARP studs all the way through, Meziere WP, Speed Inc. fuel system with 8- feed and 6- return, Bosch 420 pump, sumped 98 model tank, Delphi injectors, TNT F2 kit w/200 shot, 11:2:1 compression, and hopefully a good speed density tune by Futral. It'll go to the ground through a Spec Stage 3 carbon/ceramic clutch, my T-56, Spohn indedtructable drive shaft, and a Moser 12-bolt w/4.10's for the time being. I'm sure more will come to me in a while......
