Is the added weight of the 408 too much to make it worth it?
Ok, ok.. A little exaggerating, but with a 408ci you will notice a substantial increase in going forward. Hell my current ride still handles better than my F-body and I had a bunch of suspension work done to it. Now initially I did notice more of a lean in hard cornering, but the car still handled better than my old SS. I installed BMR sway bars front and back and back to no more lean. The difference between the alum and iron on the street is minor. I am sure you will notice more at the track, but with the right suspension you can be right there with a stock FRC with stock suspension. It will take an exstra 10hp to make up the weight and with a 408 you wont have a problem.
Thanks--Andy Trending Topics
Its not rocket science,the LS2 will be the way to go and when the LS7 block gets released that will be even better.I'll wait a yr and build a 100lb less 427 for 346 prices
Well, I see your rational for that. But one, I'm not letting my car sit for a year or more. Two, I really don't think the 427 will ever get even close to as cheap as a 346. You can get an entire forged shortblock 346 for $2700. My guess would be that the 427 forged would never be less than $4,000. And like I've said before, I don't like trying brand new things. I like to see how they do in the test of time before I spend thousands of dollars on new stuff
Not everyone wants their car to do well at the track.
Not everyone even goes to the track.
Some people just like really fun, solid street/highway rollers.
The iron block setup is the best bang for the buck, hands down.
Not everyone wants there car to do well at the track.
Nicely put
408ci Iron is what I went with in my pig 'vert. With a 200 shot, good suspension I should be in the low 10's - I hope
the 383 with a mild cam put down 490rwhp and ran 10.70's in bad weather with consistant LOW 1.5X 60's. pulled a FEW 1.49's.
was highly debating the if the extra 100lbs up front was worth it, but I built it anyway. my 408 puts out 540rwhp and runs 10.50's with CONSISTANT mid 1.4X 60's so, no traction is not an issue. have cut 1.42 to 1.47 60's and the powerband is just outrageous. I launched at 6k with the 383 and now I launch at 5k with the 408!!
. I have sprayed this bitch to very high speeds and have had no ill effects so far ( I was also able to keep an eye on my knock sensor readings while doing this which is another + to having a motor that fits well).But no matter what it is always heavier than an aluminum block so if you need every last ounce of speed out of your ride then go aluminum, if you wanna save some cash and have a mainly street car then go iron or if you are going for ultimate reliability (i.e strongest parts) then go iron as well.
