View Poll Results: F13 or Torquer-"Which one and Why"
Torquer 233/233 .589/.589 112 LSA
42
24.56%
F13 230/232 .595/.585 112(+2) or 114
129
75.44%
Voters: 171. You may not vote on this poll
F13 or Torquer Part II
Old Jul 4, 2005 | 10:30 AM
LS1Maniac's Avatar
I vote for the FM13. My FM15 makes more torque than the Torquer does .
Old Aug 3, 2005 | 08:25 AM
King James's Avatar
Originally Posted by Tranzor_Z28
I have the F13 now, and had the TSP 231/237 before it... I really like the F13, great cam for someone who drives on the street as well as the track, but doesn't have as mean a lope as my old 231/237 did. That said, you can't go wrong with either the F13 or the new Torquer.
What is the difference in your track times between the two?
Old Aug 3, 2005 | 09:10 AM
WS6FirebirdTA00's Avatar
f13 is a good mid range cam and you dont have to spin the **** out of the motor. the f13 doesnt have a nasty lope because IMO its a better designed cam and you can tune it to be smooth but still pull like a damn raped ape
Old Aug 20, 2005 | 11:14 PM
02WS6Bird's Avatar
if you go buy the amount of valve overlap the Torquer has more not much but it does. It is an equal match in valve overlap w/ the F14 if you wanted the simlar sound. the Torquer was a 233/233 but the Vr.2 is 232/234 as well so as you can see Futral cams, at similar/equal sepcs are superior. if the 230/232 is making the power of the TSP torquer at the same RPMs imagine what the F14 (same specs as the new torquer) will do and it spins a tad bit higher!!! I have to go w/ futral on this one
Old Sep 21, 2005 | 02:18 PM
black_z's Avatar
On average it seems that hte futral cams make better torque, If your looking for a nasty sounding idle, turn the idle speed down.
Old Oct 2, 2005 | 10:49 PM
vodas00ss's Avatar
im going with the F13 after reading many posts on the two cams.
my bro does have the tourquer v1 and made 408 and 410+tq which impresses me with the tsp cams.
I do have a question about the origonal post it says 230/232 .595/.585 112(+2) how does the +2 of timing affect performance or drivability?
Old Oct 3, 2005 | 10:29 PM
SPD KILZ's Avatar
F13 is a bad *** cam. Many of the big tuners will tell you it is one of the best mix of steetable power.
Old Oct 5, 2005 | 07:14 PM
Bill Bowling's Avatar
Talking
I like my Torquer 1 cam.
Bill
Old Oct 5, 2005 | 09:29 PM
AFTICA's Avatar
I'm curious about this also. Especially shift points.
Old Nov 7, 2005 | 09:55 PM
CamminV6's Avatar
I just installed a tsp 231/237 and gained only 11 rwhp over my hotcam AND lost, I said lost over 20 rwtq!!!!! DO NOT get the 231/237 for any reason!! My tuner, said FM13 or I could get his secret custom grind
Old Dec 30, 2005 | 09:57 AM
PREDATOR-Z's Avatar
How do you figure that?
377 RWHP & 374 RWTQ 08/2005 - CUTOUT, 4.10's
404 RWHP & 378 RWTQ 12/2005 - TSP 231/237, 3.73's
I see 27 rwhp and 4 rwtq gain
Old Dec 30, 2005 | 11:54 AM
  #32
HartAttack's Avatar
Both are great cams..
Old Dec 31, 2005 | 01:15 PM
  #33
kpowr82's Avatar
Must have been because he found a tuner who knew what he was doing
Old Dec 31, 2005 | 02:18 PM
  #34
cenTX-LS1's Avatar
From what I understand, the +2 advance ground in will shift the powerband down a bit in the rpm range.
-Jason
Old Dec 31, 2005 | 05:13 PM
  #35
sprydncamd ta's Avatar
i love my f13 it has good low end torque and pulls hard as hell from 2500 on great cam and was easy to tune no idle problems at an 875 idle and sounds like a monster
Old Dec 31, 2005 | 09:30 PM
  #36
WickedC5's Avatar
Hey sprydncmd ta, what lsa do you have the f13 on.
