Riocker Arm Bolt Protrusion.
Old Dec 25, 2004 | 05:44 AM
DaleMX's Avatar
Default Rocker Arm Bolt Protrusion.
This is a picture of the rocker arm bolt protruding into the intake runner. Grind it, or leave it. Let me hear your opinions please. I am more inclined to leave it, but if other experience shows otherwise I’ll grind.
Yes, I will seal it up with some RTV.
Thanks for your time.
http://www.circuitflex.com/RockerBolt.jpg
Old Dec 25, 2004 | 08:41 AM
PREDATOR-Z's Avatar
Shorter bolts......But still seal it.
Old Dec 25, 2004 | 07:20 PM
Beast96Z's Avatar
I just cut the little tip off the bolts that went into the intake side. Sealed them with ARP thread sealer.
Old Dec 25, 2004 | 08:17 PM
CAT3's Avatar
Restricted User
Have left them alone, but I would like to get either shorter bolts, or cut them, then seal it. Just to see if it would make any difference I guess.
Old Dec 25, 2004 | 09:04 PM
John02SS's Avatar
Only thing with grinding it will be if the hole left behind will cause more airflow turbulence than the bolt sticking out. I just sealed mine.
Old Dec 26, 2004 | 04:05 AM
Inspector12's Avatar
TT-TECH Veteran
I marked and cut the bolts off I wouldn't know if it make a difference or not. I used loctite after that.
Old Dec 26, 2004 | 05:19 AM
DaleMX's Avatar
Thanks guys, I'll cut and seal it up.
