I need a head bolt tap
Old Dec 26, 2004 | 11:48 PM
laz's Avatar
laz
Default I need a head bolt tap
Ok anyone know where i can get a tap to clean the threads on a ls1 block the headbolts where a ****** to remove and i wanna tap and clean the threads for the new arp head bolts Thanks in advance Laz
Old Dec 27, 2004 | 12:50 AM
Beast96Z's Avatar
Take one of the bolts down to the hardware store and find a nut that fits it. Look at wht size and pitch the nut is and go by that tap.
Old Dec 27, 2004 | 01:51 AM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default Head bolt threads
You will not find a tap. The threads are an odd ball size and pitch - 11mm x 2.0. You do not want to run a tap through the head bolt holes anyway because you will drastically weaken the threads. The threads are roll formed not tapped.
The only place I know that has a thread forming tool is Time Sert. Problem is he will not sell you one unless you purchase a complete kit. A couple of guys broke his tool off in their blocks (not easy to do) and sued Time Sert.
I can help you if you are in S. Ca. I reform the threads in every used block I install the Darton MID sleeves in.
Steve Demirjian
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old Dec 27, 2004 | 04:09 AM
DaleMX's Avatar
They are hard to clean. I tried the bolt side grind method and it worked to a degree, but still left the threads clogged. In the end I just took the arp bolts and ran them in and out quite a few times then blew the holes out. By the way, just blowing the hole will not get the crap out of the bottom, attach a straw to the air hose and push it to the bottom of the hole and hit it, all types of crap will come out. Those holes need to be inspected with a flashlight to make sure there is nothing hanging at the bottom or the bolt will bottom out and give a false torque reading.
Old Dec 27, 2004 | 10:58 PM
laz's Avatar
laz
Ok guys i was lucky enough to find a bottom tap i used a 1/4 drive snap on extension with a piece of thin cardboard to make it stay together it fit and i was able to clean the threads with out any problem no material removed and the bolts went in by hand this time i blew the junk out and then vacumed each hole bolted my heads and torqued them down so far so good thanks to Steve and Dale for your help i should be back on the road soon .
