What are the cheapest and stronger than stock pistons for an LS1?
Old 12-27-2004, 06:17 PM
14 Second Truck Club
Hemi Killer's Avatar
Default What are the cheapest and stronger than stock pistons for an LS1?
Anyone know?
Old 12-27-2004, 07:53 PM
jrp
SN95 Director
jrp's Avatar
diamond piston are good bang for the buck. i believe they come in 3.898 and 3.905 for off the shelf.
Old 12-27-2004, 08:15 PM
Bo White's Avatar
Also there is Probe and Malhe(?) for stock replacements.
Old 12-27-2004, 08:27 PM
kickassT/A's Avatar
another vote for mahale pistons. under $400 bucks a set on ebay with rings. can't beat that
Old 12-27-2004, 08:56 PM
LS1_PNYTAMR's Avatar
which is better.. 3.893 or 3.905 and go ahead and clean up the bores with a slight hone and make sure they will seat?
Old 12-27-2004, 10:58 PM
Sawzall and Welder Mod
Whistler's Avatar
I would do the 3.898, that will leave a little room to grow on if you ever want to do another build. The bores will need to be honed with either set though.
The 3.898 set will need to be honed to seat the new rings, plus the forged piston requires a few thou. more piston to bore clearance than the stock hyperute's.
Old 12-28-2004, 12:13 AM
Where can you get new ones from? Website? Thanks for all the replies.
Old 12-28-2004, 07:56 AM
Smitty's Avatar
Check with TSP>>>>>>>>>>>>>>>>>
Old 12-28-2004, 11:37 AM
kickassT/A's Avatar
pm inspector12. he put those in his motor. i'm sure he will have more info for you
Old 12-28-2004, 01:24 PM
Jon@Texas-Speed's Avatar
I have the Mahle pistons in stock
Old 12-28-2004, 01:32 PM
yea id like to run the stock rods and stock crank... i dont see them breaking on a 150 shot that goes a lil lean, but piston damage at one point or another seems inevitable!
