What do I need to know? Going to Agostino Stage III Heads & G5X3 Cam
I have a line on some Agostino Stage III's
2.08/1.60 valves flow numbers
lift Int Exh
100 79 66
200 142 128
300 209 162
400 251 199
500 287 222
550 298 228
600 311 231
these are with 941 springs. Also a g5x3 cam. What do I need to know in order to make this switch? I currently have:
mms stage I heads
mti c1 hammer cam
918 springs
7.35" Chromoly pushrods
Additionally, how much more power should I make over my current setup? I am assuming since I have all the boltons I should have about 380-390 rwhp
Thanks in advanced!
lift Int Exh
100 79 66
200 142 128
300 209 162
400 251 199
500 287 222
550 298 228
600 311 231
mms stage I heads
mti c1 hammer cam
918 springs
Thanks in advanced!
Get rid of the 918's and go Crane duals...
Thats a big cam and I'd feel safer w/the dual springs,other than that a timing chain,oil pump,gaskets and a retune and its done.I'd opt for a LSX/90 if u have the coin as that head/cam setup wil love it.
Should make good power...
Also, here is my setup:
Engine:
LS1 lid and K&N filter
MTI C1 "Hammer Cam"
918 springs
Oil pump (1000 miles)
New rings
LS6 intake
MMS Stage I heads (2.02/1.57- milled .030") for higher compression
175 degree thermostat
LS1 edit tuning
NX wet kit
Transmission:
Rebuilt 4L60E
Pro Torque 3600 stall.
Exhaust:
Mac headers with off-road y-pipe
Borla Exhaust
Dynomax bullet muffler
Engine:
MTI C1 "Hammer Cam"
918 springs
New rings
LS6 intake
LS1 edit tuning
NX wet kit
Transmission:
Rebuilt 4L60E
Exhaust:
Borla Exhaust
As long as u notch the pistons u will be fine.
Spanky is right,you'll give up alitte with those big heads but it'll still make good power.
Now u wanna do something trick,just pull YOUR heads and notch the pistons,add the MS3 cam to your setup w/the LSX/90.I bet it makes KILLER power and u wont have to spend $$$ on the S3 heads.
