For those who think custom cams are best... please explain why!
Originally Posted by QuietTahoe
After 30 years in the performance industry, one thing I have learned is that no one person and no one company has all of the answers!!
here is my opinion on custom grinds.the farther away from stock you go with your motor,the more important it is to match your cam to your heads/intake/exhaust system,AND the intended use of the car.their are some very good shelf grinds out there that the sponsors have come up with that work well with stock and ported heads.but i think you can maximize performance with a custom grind,it depends largely on your goals. i'm going with a custom grind for my new H/C combo since it's only a little more than a shelf grind.i don't expect huge gains over,let's say a TR224 for example,but i expect it will give me more power under the curve and better drivability.that is worth the extra 75.00 or so to me.but maybe not to someone else with different goals.
Hype and snake oil, period. Search the high dyno threads and low ET threads, and see how many are shelf cams and how many are custom cams. Despite what the custom cam "salesman" say, a shelf grind usually works best. Anyone have any specific examples of any 500rwhp H/C cars using a custom cam? Anyone have any examples of any 10 second cam-only cars using a custom cam? There are a couple of 500+rwhp H/C cars, and a few 10 sec cam-only cars, and none of them (as far as I can recall) are using a custom cam. It seems like it should be awfully easy to duplicate/surpass those results since they are using shelf and "one size fits all" cams that the so called experts swear will not work. Where are all of the custom cam success stories? If a shelf cam can produce 500rwhp on a H/C car, shouldn't a custom cam be able to surpass that pretty easily? Even shelf cams have a TON of research and trial and error, its not like MTI, LG, TR, or anyone else just sits down and says, hhmmmm, 230/236 sounds good, lets have 500 of them made. I know for a fact that there were 3 or 4 different LG G5X3s before the finalized X3 was out. Just my .02. I'd love to be proven wrong, but have yet to see any examples of where a "custom" cam outshined a "shelf" grind.
Shawn
Shawn
Are you saying that the cam designers at Comp, Crane, Crower, Isky etc have never considered stroker motors or aftermarket heads? No one in any type of serious racing runs stock heads anymore! Those guys are working with "super-custom", "high-buck" combinations every day. They ARE working with the guys who order up 8 or 10 cams with the same lobe but with different LSAs and duration changes of 1/2 to 1 degree. If anyone is on top of equating head flow numbers, etc. with cam design it is those guys. Are you suggesting that the LS1 "tuning gurus" (and I mean that totally respectfully) are supplying the entire lift table to the cam manufacturers. I suggest that, more likely, they are telling the big guys' cam designers what they think will work and the cam designers are designing the cams! These same cam designers are the guys who design the "shelf" cams. I'm sure they don't try to design bad lobes so that some guy with a used cam grinder can show them up! If I was going to have a custom cam made, I would certainly track down the most talented guy at one of the big cam companies! It's not just ability and passion, it is also about resources and personal networks!
Shawn
Shawn
Originally Posted by critter
Note that "outperform" does not necessarily mean best HP or best ET. It might mean best driveability, for example.
Now why did you have to destroy your credibility with that statement? Anybody who has been following these threads knows that no one, expert or not, has ever said that "one size fits all" cams will not work. The claim is that a custom spec'ed can (and probably will) "outperform" a "one size fits all" cam. Note that "outperform" does not necessarily mean best HP or best ET. It might mean best driveability, for example.
Shawn
IMO, a guy like 66deuce or a similar guy who wants a "good street/strip car that i can hop into and drive 500 miles and not worry about anything" may (and probably would be) just be served as well with a proven shelf cam (TR224/224, TSP 225/225, etc) as he would be with his custom cam, despite what the custom cam "salesmen" say..
Shawn
Shawn
chuck
ohhh my
-Yes, a shelf cam may perform as well as a custom.
-Was it made exactly for your setup? No. So chances are if the custom cam grinder is good. It will perform better.
Copying takes place all the time. A cam isn't a shelf cam until I can go up to the vendor and say I want part number XXX. and then buy.
6600 rpm clutch dump of death Administrator
I think many folks are getting off in a rut, and not using their brains. Let me try to spell it out in real simple terms...
There are folks out there who run shops who know no more about cam design than most of you. The singular advantage they have is they have a shop, and they can sell a cam. Most shops have a dyno, so they can at least experiment with those cams before they sell them to folks.
There is nothing wrong with trial and error experimentation. My buddy Sam down in Australia ordered about 40 cams and did just this. He ignored all the "conventional thinking" that folks had here in the states, and did things based upon his experience based on many year of building cars. He ordered the same lobes with various splits, and then advanced and retarded them and made hundreds of engine dyno pulls to find out what worked. Again, there is nothing wrong with this approach. Look at Lou. Lou's been racing for a long time and he's applying what he knows and based on his experience to design a cam. BTW, I like Lou. I talk to him on the phone all the time. He and Louis are really good guys. Lou is a fantastic race car driver, and he's a racer at heart.
There are another group. There are other shops who see what other shops are doing and they simply pick something close to what "everyone" else is doing. Since those cams are "proven", chances are these cams will work too.
Now, you have one other group. The actual custom cam grinders. What do these folks have? They have the luxury of both of the above method I outlined in most cases (they have experience, and they test). The other thing is that they often use some analytical tools that have been developed to help race teams and individuals focus in on more "ideal" cam designs.
Here is something for you to think about. Comp Cams has thousands of lobes. The XE-R line for the LS series lobe is a SMALL portion of this selection. If folks think the world ends with XE-R then you have to understand they are not seeing the big picture. They also basically don't understand how aiflow requirements and port design dictate lobe selection. And thats cool, not everyone does.
Lets look at what you can do. You can overscavenge your exhaust. You can over cam your engine, and throw too much lobe at it. You can be a big dyno queen with a big peak HP number, and you can be really slow. But hey, you've got a big dyno number to be proud of. So, thats something...
On the other hand you can determine what RPM you want to run. How much your heads flow. You can determine you I/E %. You can look at what headers you run. What gear is in the car. How much it weighs. And you can look at what the car is going to be used for, and then determine the lobes and the cam design.
Both criteria I've outlined work. Both may have similar results if you only look at one parameter (like peak hp). If you discount things like drivability, midrange power, or anything else then you might be real happy. Why do the truly custom cam grinders use lobes that vary rather than just sticking to one family of lobes? The answer is quite simple. Sometimes a motor needs less lobe. Sometimes a motor needs more lobe. This ammount may vary based on lift. Sure, you might split the difference, but it like a stall converter. If you need 3000 RPM of stall speed, why put a 5200 RPM converter in the car? It might sound cool. It might bark the tires, but you loose a ton of your powerband.
For those who think a camshaft optimized for your particular combination is inferior to a mass produced cam optimized for no combination please explain why you think this is...
#32
It's like GM's approach to taking care of the piston slap in these engines. "It's perfectly normal"; "It's just a little noise; it's not a problem." Knowing damn well it should be repaired, it's avoided because they don't care to deal with it. It's too much of a hassle...Sound familliar?
No personal offense directed at anyone one of you, but some of you (sorry for being so blunt) are talking out of your asses. You're either avoiding the truth for whatever reason, or just ignorant-sorry...A custom cam is made to yield optimum results for a specific application-period. No one cam grind is optimum for two applications-period. With all engine specs being equal, the type of use/track the vehicle will see will vary the cam design as well for optimum results.
Just as J-Rod said: "For those who think a camshaft optimized for your particular combination is inferior to a mass produced cam optimized for no combination please explain why you think this is...
Where's EDC and his opinion bashing comments when they're actually needed
#33
Here is a marine engine combo one of my customers just got done with.
Goal: Provide a package to compete with Mercury's HP500 that is a 12K option over a base 502 engine. Make the package user friendly for the boat owner to install. Must be cost effective, under $6K
502cid - 100% stock short block other than min. deck cut to make flat
8.8 compression. Did not zero deck - pistons .012" down + .040" headgasket
850 Sea Demon 82P 90S
HVH 1" Super Sucker
HV/Brodix 2000 Intake
Canfield 310 heads / CNC Chamber / No Port Work
Cam - custom Hyd Roller Just under 225 at .050 I w/112LSA
2" Primary Schoenfield Headers - dyno mufflers
Will test Gill Exhaust again when done testing in this state
Belt driven Sea Water pump working - cross over - alternator working - no PS pump.
89 octane fuel - yep, Winter Blend right from the gas pump.
35 Degrees total timing - HEI external coil distributor ( yes, the computer one) with Jacobs amplifier/coil
RPM HP Torque
2100 194.3 483.8
2200 206.6 495.67
2300 217.5 498.52
2400 231.0 505.70
2500 243.9 512.60
2600 256.8 519.00
2700 269.2 523.36
2800 279.9 524.64
2900 288.2 521.78
3000 295.2 516.70
3100 302.8 513.17
3200 312.2 512.08
3300 323.2 514.40
3400 336.7 519.97
3500 351.9 527.69
3600 374.4 542.69
3700 387.9 550.14
3800 406.6 562.41
3900 424.7 572.21
4000 440.7 578.35
4100 457.4 584.13
4200 468.2 586.44
4300 480.3 586.50
4400 490.9 585.93
4500 500.4 583.75
4600 508.8 580.29
4700 515.1 576.90
4800 526.3 575.77
4900 531.4 569.77
5000 536.0 563.20
5100 540.2 556.26
5200 540.9 546.34
Valve events and overlap are critical with wet exhaust. . .you can really screw an engine up. The HP 500 merc has a much larger cam, 234/242 @ .050" but this engine has much better heads. Could a shelf work. ..yeah. Could it make more peak power. . .yeah. But this custom cam is designed to make power over a broad range to move 8K pounds of fiberglass.
This combo exceeded the engine builders goals and for $5K to your door give's the performance boater a great bang for the buck.
Chris
HVH 1" Super Sucker
RPM HP Torque
2100 194.3 483.8
2200 206.6 495.67
2300 217.5 498.52
2400 231.0 505.70
2500 243.9 512.60
2600 256.8 519.00
2700 269.2 523.36
2800 279.9 524.64
2900 288.2 521.78
3000 295.2 516.70
3100 302.8 513.17
3200 312.2 512.08
3300 323.2 514.40
3400 336.7 519.97
3500 351.9 527.69
3600 374.4 542.69
3700 387.9 550.14
3800 406.6 562.41
3900 424.7 572.21
4000 440.7 578.35
4100 457.4 584.13
4200 468.2 586.44
4300 480.3 586.50
4400 490.9 585.93
4500 500.4 583.75
4600 508.8 580.29
4700 515.1 576.90
4800 526.3 575.77
4900 531.4 569.77
5000 536.0 563.20
5100 540.2 556.26
5200 540.9 546.34
Chris
#34
LS1TECH Sponsor
HVH 1" Super Sucker
RPM HP Torque
2100 194.3 483.8
2200 206.6 495.67
2300 217.5 498.52
2400 231.0 505.70
2500 243.9 512.60
2600 256.8 519.00
2700 269.2 523.36
2800 279.9 524.64
2900 288.2 521.78
3000 295.2 516.70
3100 302.8 513.17
3200 312.2 512.08
3300 323.2 514.40
3400 336.7 519.97
3500 351.9 527.69
3600 374.4 542.69
3700 387.9 550.14
3800 406.6 562.41
3900 424.7 572.21
4000 440.7 578.35
4100 457.4 584.13
4200 468.2 586.44
4300 480.3 586.50
4400 490.9 585.93
4500 500.4 583.75
4600 508.8 580.29
4700 515.1 576.90
4800 526.3 575.77
4900 531.4 569.77
5000 536.0 563.20
5100 540.2 556.26
5200 540.9 546.34
Chris
HVH 1" Super Sucker
RPM HP Torque
2100 194.3 483.8
2200 206.6 495.67
2300 217.5 498.52
2400 231.0 505.70
2500 243.9 512.60
2600 256.8 519.00
2700 269.2 523.36
2800 279.9 524.64
2900 288.2 521.78
3000 295.2 516.70
3100 302.8 513.17
3200 312.2 512.08
3300 323.2 514.40
3400 336.7 519.97
3500 351.9 527.69
3600 374.4 542.69
3700 387.9 550.14
3800 406.6 562.41
3900 424.7 572.21
4000 440.7 578.35
4100 457.4 584.13
4200 468.2 586.44
4300 480.3 586.50
4400 490.9 585.93
4500 500.4 583.75
4600 508.8 580.29
4700 515.1 576.90
4800 526.3 575.77
4900 531.4 569.77
5000 536.0 563.20
5100 540.2 556.26
5200 540.9 546.34
Chris
Interesting Chris. My 23' Stingray is due for a re-power. Currently a 454 Mag.
#36
LS1TECH Sponsor
Mikey,
23 Rinker here, I'm thinking 496 stroker!!! Hey got mail from you, so you should get mail from me.
Chris
Chris
#37
1 Post
When some people talk and/or post... it reminds me of an old cliche'...
"It's better to remain silent and let people "think" you are an idiot than speak up and remove all doubt"
Some people on this forum just need to be silent on this topic...
/awaiting flamefest
Ed
#38
Lets say you got a custom grind cam from XXX cam distributors made for your car... Now youre bragging to the whole world how your custom grind is the best ever made and it smokes the G5X3 because its custom taylored to your setup... Then Mary comes along and has that cam duplicated because she noticed in your sig she has the same combo as you and wants those numbers... Is your all-so-holy custom grind cam now an "Off the shelf" cam?
#39
Originally Posted by EDC
OK NoseUp
/awaiting flamefest
Ed
/awaiting flamefest
Ed
#40
I believe in getting several different custom grinds, and experimenting on the engine dyno. I know this is not practical for most, but it's the best way to go about finding that last extra ounce of power. I've tried three so far on mine, and will be trying another here shortly. Each is a custom grind cam made to fit my combo. Not from Comp, Crane, Lunati, or Crower. They are true race grinds. The only way to know which will work best is by experimentation.
