bolt holes behind oil pump?
Old Apr 19, 2003 | 01:11 AM
miltisync's Avatar
Default bolt holes behind oil pump?
there is 2 bolt holes behind the oil pump. im not sure if a cover or something else needs to go there. the machine shop pointed it out to me. should i worry about it?
thanks
Old Apr 19, 2003 | 03:57 AM
DreamWeaver's Avatar
Default Re: bolt holes behind oil pump?
??? I just replaced my oil pump and don't remember any bolt holes or plates/covers behind it. There are 2 bolts on each side of the pump and the oil passage hole on the drivers side
Old Apr 19, 2003 | 09:41 AM
Tin Indian's Avatar
Those bolt holes are drilled for a chain damper.
At one point in time, GM was going to install these in the LS1. Never happened.
Some year cars have no holes. Some have holes with no threads, and some have threaded holes. BTW, my 98 has threaded holes.
If you are not installing a chain damper, don't even worry about those holes. Below is a pic of the damper installed (pump removed)
I don't know of anyone using this damper.
Here is the link: http://www.paceparts.com/product.asp...&1=256&3=40918
<img src="http://turbota.homestead.com/files/GM_Chain_Damper.jpg" alt=" - " />
Ron,
Old Apr 19, 2003 | 01:42 PM
miltisync's Avatar
thanks alot for the info <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Apr 19, 2003 | 01:58 PM
DrkPhx's Avatar
I have that installed on my car.
Old Apr 19, 2003 | 02:39 PM
jst psi's Avatar
that damper looks to be made of nylon, it seems like a good idea but after a while small shards shaved off by a lose timing chain dont sound good, maybeim just thinking to much <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Old Apr 20, 2003 | 10:12 PM
Dale C's Avatar
My car is an early C5 it was the 73rd one built. It has the damper on it stock.
