home made lifter tool question
Originally Posted by Bluehawk27
I really didnt see what the big deal was about the pick up tube, all i used was the ratcheting wrench with a shop rag in the pan. I got it out pretty easily and putting it back in was only slightly harder.
I am curious about gaskets, what kind of gaskets does GM use, are they a silicone reuseable kind? Any silicone scraping involved? Did all of you guys changed your oil after the swap? My car is only going to have around 2500 miles on it when I do the swap, so I won't worry about the timing chain or oil pump. Any of you guys done this swap on a GTO, or helped with one. I am curious about the cam clearing the AC condensor in the GTO.
