what are the stock cam and valve spring specs????
Old Jan 3, 2005 | 12:34 PM
2000ws6transam's Avatar
Default what are the stock cam and valve spring specs????
i cant find them anywhere!! i wanted the spring rates for a 98+00 ls1 along with the lift of the cams
Old Jan 3, 2005 | 12:44 PM
BlueSix's Avatar
https://ls1tech.com/forums/showpost....84&postcount=6
Old Jan 3, 2005 | 12:45 PM
BlueSix's Avatar
Everything you ever wanted to know..... (hope the valve spring specs are somewhere in here...)
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/213148-jrp-s-faq-commonly-asked-questions.html
Old Jan 3, 2005 | 12:49 PM
still nothing about the valve springs?
Old Jan 3, 2005 | 12:53 PM
BlueSix's Avatar
Here's all you need to know about stock valve springs....they suck.
Out of curiosity, why are you needing the info on the stock springs?
Old Jan 3, 2005 | 12:58 PM
sorry, i found it!! thanks for all the help!!!
Old Jan 3, 2005 | 12:59 PM
i was going to use them in my GTP with a small aftermarket cam, but it looks like i still need to go with the ls6 springs
Old Jan 3, 2005 | 01:22 PM
Bearcat Steve's Avatar
From what I understand, the factory springs are just good enough to handle the stock cam and nothing else. If one has any illusion of using stock springs for anything other than a stock cam, please purge it from your mindset.
