Is it ok to use the 3M Rolock Cookies to clean the deck (block)
I bought some 3M Rolock cookies (brown, soft ones) the prep the block where the heads go. Is it ok to use that, or will it scar, or even worse, be to much where it will make it uneven? I would think it would be perfect as long as I don't stay in one area to long. Anyone use these before, let me know if its ok. Thanks
wrencher
Re: Is it ok to use the 3M Rolock Cookies to clean the deck (block)
If you had to clean anything else BUT the deck you can use the 3M rubber brissle disc, but I would only use the white one's.(fine)The roloc's tear up cast iron, even the red aluminumn ones.
