alternator problem found! need help
Old Jan 10, 2005 | 10:53 PM
LSONE's Avatar
Default alternator problem found! need help
alright, i found the problem and i now need your advice. this red wire:
that connects to this:
that plug goes into the alternator, and thats why i have no voltage. what do you think the best way to get that red wire back into that plug is?
Old Jan 10, 2005 | 11:00 PM
kossuth's Avatar
I would go to the dealer and get a replacement plug. They sell service ends, costs about $20.
Old Jan 10, 2005 | 11:02 PM
LSONE's Avatar
do you think i'll need a part number? what will it come with?
Old Jan 11, 2005 | 12:14 AM
ls1itldo's Avatar
Mine did the same thing, i just pushed the pin connector out of the plastic connector and soldered the wire back on the pin and pushed it back in, works beautifully
Old Jan 11, 2005 | 05:45 AM
BTL FED's Avatar
What he said just look at the back of the plug, you will see a small metal tang you can depress to pull the metal out of the plug, once you get it out, you can reattach your wire to it, mine did the same thing
Old Jan 11, 2005 | 06:50 AM
kossuth's Avatar
shouldn't need a part number just tell them you are looking for the replacement end. They aren't too hard to get. I had to order one for my S10 swap because I'm using C5 accessories and the C5 alternator is wired differently than the S10 or the fbody unit. Just be sure to get a pinout from the service department so you can get it put back together right. You could try to solder the connector back in but if the wires actually pulled out of the metripack terminal then you are screwed. I have had no luck with those small little bastards. The larger ones aren't bad, but the smaller ones aren't worth messing with IMO
Old Jan 11, 2005 | 03:13 PM
JoeyGC5's Avatar
Radio shack will have pin removal and insertion tools, as well as terminals.
Old Jan 11, 2005 | 03:18 PM
tim99ws6's Avatar
I had the same thing happen to my alterantor wire....
Go to the dealership like someone else said....They have the replacement there with the wire already ran to the connector. Then solder, or connect that wire to the red wire...and you're set!
Old Jan 11, 2005 | 10:16 PM
LSONE's Avatar
what did you say or ask for when you got there? i dont really want to explain my whole situation to them.
Old Jan 11, 2005 | 10:27 PM
tim99ws6's Avatar
I asked for a replacement weatherpak connector for the alternator.....
It's just a universal weatherpak with the wires already plugged in all four holes.....I just cut off the wires not being used...
Old Jan 11, 2005 | 10:35 PM
LSONE's Avatar
i see... thanks
