newbie heads/cam install
i'm sure 5point7 would come and help me if i needed it...i think he did his cam install...i'm not sure though...if not i have a few people that could (best friend's dad is a mechanic) so we shall see
-Do you have patience?
-Do you have a second vehical or means to do without the car for a week or so?
-Do you have most of the tools that LS1howto requires?
I would ask if you had a garage but I assume being in Florida, the weather is warm and work can be done outside.
If you answered yes above, I would not see any problem doing a basic H/C install. I just did my first cam swap all alone, slow rolling, over the coarse of 6 days and everything went successfully. The only thing that might get hairy is if you decided to mill the heads, and thus would need check P/V clearence and notch the pistons. That could be a little complicated. I don't have experience with that one, but hope to tackle that one within a year. Have cofidence in yourself and take you time. Don't be on a schedule with this kind of stuff and you'll be fine.
Im going to start mine in a few weeks if you havent started yet ill tell you about it.
Good Luck.
i'm sure 5point7 would come and help me if i needed it...i think he did his cam install...i'm not sure though.I just completed a cam swap in my car less than a month ago with the MAJOR help from "distortion_69" and his brothers. In fact, I only helped on little things like intake bolts and spark plugs. The actual pulling of radiator, cam swapping, valve spring install, etc. I didn't even do. But I watched and learned a whole lot. I had an awesome time.
My biggest advice would be:
1. be patient
2. leave ample time for the install (ie, don't try to squeeze it into one weekend if you have to work on monday morning)
3. have a spare car to drive around b/c you might need to make runs to AutoZone, Home Depot, etc. for little things
4. do it indoors away from the elements if possible (we did it in 30 degree weather, very difficult)
5. have the right tools
6. don't do it alone
Another thing that took me long was the my pulley install (did this a few months ago) , Didn't have a 3 jaw puller. Used a 2 jaw and had to get it situated correctly. Had to make my install tool, etc. Second time around it was real quick. 2 jaw worked great on the ASP and the install tool worked great too. See what I mean? Until you know your tools, and the process to take off some of the "seemily" simple stuff it can be time consuming.
...just kidding
p.s depending on the cam you may want to get springs. dont want to take shortcuts
