A little help here!!
Does anyone know why, if it rains or I wash my car, my car will run like ****? It hesitates and bogs like a spark plug wire is pulled. It will do it for like 15mins then run fine. It just started doing this for about a 2 wks. Thanx in advance.
After u wash your car pull the plugs and see if they have water on them. Make sure you are not getting water on the maf or in the motor.
Also could u come over and wash my car. J/K
I realy want u to send you G/F to wash my car.
Definitely check for water getting onto electrical components, fuses, harnesses etc.... If you wash your underbody also check your wire connections under there, most importantly the o2 wires. Most people that have this problem take some dielectric grease and grease up every connection visible and reachable they can do. Good Luck
