AFR 205's?
My thoughts exactly....Few manufacturer's, if any, spend the time I do posting here to help and aid you guys in completely understanding the product and it's benefits, as well as trying to give insight on putting together the right combinations. Better than 50% of the time I spend posting is on MY personal time. I refuse to answer the same questions 50 times...especially very "general" questions....when I have taken the time to write volumes of information IN DETAIL that can easily be accessed by doing a search under my name. What good is a "quick" answer anyway when you can do a search a find a much more detailed response which you will probably gain more knowledge from. I am the Sales Mgr. at AFR and I handle most of the R&D and design work (anything airflow related, ports, chambers, etc.)....the time I decide to spend on the internet is purely at my discretion and should be considered a "bonus". I do my best at handling questions posted to me via PM's in a timely manner and try to get everyone handled. It's all about being efficient and answering the same questions over and over again is counterproductive, not to mention starts boring the life out of everyone reading them for the third, fourth, tenth time etc.
I find that when I am in need of information and decide to do a "search", I get the information I need and then some almost immediatly, without having to wait for other people chiming in on a new thread regarding a topic that more than likely has been discussed 100 times over. If I can't find the information I will start a thread posing that question or concern, but not before at least trying to see whats already out there. Doing a search is more than just being "helpful" to yourself....it shows courtesy to the other board members so THEY dont have to type the same %$#* over and over again....
I know JRP can relate.....LOL
Hope you guys can understand and respect that.
Regards,
Tony M.
my whole point was that if you're takin the time to post a reply might just as well answer the question ... if you want to tell someone to use the search button go for it, nothin i can do to stop you and nothin you can do to stop people from askin the same questions 100 times over ... i just like assuming people aren't idiots and know there is a search button and would of used it if they had wanted to
i do think you will be tellin a lot more people to use the search button though, since ls1's are pretty old and just bout every topic that can be discussed pretty much has ... might as well turn this site into a search engine for ls1 information, no need for a forum everything's already been discussed.
as long as you're replyin to this thread tony, how come the only cam i've heard of bein recommended with the 205 heads is the afr 224/228 and haven't heard of any other cam workin well with those heads? doesn't seem like too many options once you throw those heads on, everyone with afr 205 heads is gonna end up with the same setup.
Our "emissions" cam is a 220/224 stick on a 115 LSA. It will still pull strong to 6700 or so with typical bolt-ons and the AFR 205 heads.
Good luck...enjoy the AFR's.
Tony M.
Can I ask a few questions on this.
What heads did you come from?
Where there any other changes?
Do you have a dyno overlay of both heads with A/F on them?
Aside from peak numbers, were there losses or gains under the curve?
I honestly find it somewhat hard to believe a straight across head swap made you drop 30rwhp. I'm not saying it is not possible, but that seems a little weird if you ask me.
2. Went from a Corsa with a Bullet in the I pipe to a MagnaFlow, no bullet.
Also added a ported TB. Both were tuned. I will see if I can find the graphs.
If I remember right, the under the curve was close on both heads until up top.
Here is a link where the dyno graph is posted....
http://www.norcal-ls1.com/forum/showthread.php?t=36667
Dan
