AFR 205's?
thanks
search button is great guys, but when it takes as much time as typing "use the search button" to answer a question, why not just answer it? you're already takin the time to type a reply anway, might as well answer the question.
and no offense to tony, run your business how you like, but i would of expected you to at least take the time to answer the guy since he is asking bout your heads. to me it seems that when you have a potential customer you try to be as helpful and informative as possible ... yes you might be repeating yourself 50 times but how's that any different when you get in-person customers in your shop, are they suppose to know what questions some guy that came in the other day asked and what the answer was?
btw i think some of you guys pick and choose which questions you'd like to answer and which to just say use the search button and it has no bearin on whether the questions was asked a million times or not ... a thread was started bout ls6 heads vs ls1 heads and was extensively explained and this thread bout afr heads was just ignored ... i'm pretty sure if i'm not mistaken both ls1 and ls6 heads have been out much longer than afr heads and the there would be a lot more to information on that topic using search than this one.
VaNDaL*SS* The AFRs are great heads! Get the 66cc and if you don't already have the cam, get the cam AFR recommends with these heads. I believe it is a 224/228 cam on their grid. Or maybe Tony could share what it is.
Need I say more?
Plus, most of the laughter was directed towards Jerami.... AFR's are some of the best, or the best on the market. Dan
btw, yes a search would help, it definitely would give the guy a lot more information, but would answering his question kill you? who knows something more could come out of a little question ... like have you ever heard the results wildheart posted before from any other afr thread?
this is gettin way off subject ... either help the guy with his questions or close the thread cause it's not going anywhere if the discussion conitues like this.
