Cranks interchangable?
Um that would be the stock stroke. 3.633. Yes it will but it will cost you more in the long run.
The ls1 crank is lighter than the 6.0. This mean at the mechine shop they will have to add more weight. AKA more money.
which companies make stroker cranks for the 6.0 is more what i mean is it the same as the LS1 crank and up to what stroke can you get. all i find LS1 and LS6 specific cranks, no 6.0.
are they the same
are they the same
are they the same
are they the same
If it is a Gen III crank it work with all GenIII motor. The 4" crank for the ls1/6 is the same one that will go in a LQ4/9. Call Thunder racing or TSP or any of the other sponcers and they will get u what u need.
