COMP CAMS XE-R cam...
I don't care about times. I just like the way the car runs and sounds!
Pushrods are comp and lifters and rockers are stock, although I'm probably going to change the lifters to Comp-Rs and the rockers to Comp adjustables.
Mike Morris and his crew did a wonderful job!!!
236/239 .600/.610 111 lsa 107 icl. It peaks about 6,300 and it is DONE by 6,500. It think it would work fine with AFR 205's.. BUT there are MUCH better cams out there than the F15. It really hasn't impressed me for as large as it is. Do some searches under my username in the dyno section to see some of my results.
You may want to check out this thread, or maybe you already caught it, over at LS1GTTO.com:
http://www.ls1gto.com/forums/showthread.php?t=13413
We just finished up a Maggie'd A4 GTO and added a our Stage 3 supercharger cam. It is a 222/230 115+4 XER cam and she gained 50RWHP. All of the info is in that thread and should help you out.
On jubjub's car, it is actually a 226/230 114+1 XER with the 60cc AFR 205's. The cam AFR suggests with these heads is a 224/228 XER on a 114 and this is just one step up from there. We have had great results with this cam in other applications and wanted to see how it faired with the AFR's.
Hope this helps.
Mike Norris
I've read a lot of negative about Comp Rs. I think most of the negativity could be negated by a good set of adjustable rockers. Getting the pre-load set on those is critical. Get them set just right and I'll bet you have a rock solid valve train. BTW, I'm just now starting to educate myself on this stuff since I've had my H/C install. I've had the car back for less than a week!
