Tricks to change rear passenger spark plug
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by NataSS Inc
A Coil relocation kit helps alot along with a pair of skinney bitch arms (much like mine). I can get all 8 from the top and have them done in about 15-20 minutes.
the local guys just watch and are discussted when I do my plugs.
I'm with you...Us skinny boys have it made. Hell I've only got the coil packs held on with two bolts each. Any more than that is just extra weight. LOL
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
6 Second Club Moderator
Originally Posted by foff667
i always change that one from the bottom...near impossible from the top with popeye arms like mine.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Originally Posted by WHPLASH
Next thing you'll tell me to take out the fuel tank. LOL
!heater, !AC...
best free mod out there, the #8 is the easiest to change.
Of course, you'd have to live in San Diego to daily drive year round with no heater or AC.
I remove the passenger air tube and push it out of the way, then practically stand on my battery. Then I put my left arm straight in and parallel to the head, and assemble the extension, socket, swivel, and ratchet, one-handed and remove the plug. It takes awhile, and almost requires being a magician.
#32
go ahead and take the coil pack bracket off, put the socket on the spark plug, then attach the ratchet right onto the socket, and take a nice sized open-end wrench and use that for leverage to push on the ratchet handle to break the spark plug loose. once its loose its cake walk.
