best sleeper cam for spray?
so what is a good mild cam for 3000 converter, 3.73's and a 100-150 shot?
would a ls6 cam work well? i mean the cam and springs and pushrods would be cheap and they would last a long time.. i could kinda sneak up on ppl with an xtra 25-30 hp, rather then being everyones target with an extra 50!
would i be better off with a tr220 or 224 or one of the mti cams? but im sure they will still idle choppier then the ls6 cam, + cost more, and if the idle is even going to hint i have a cam, i might as well go as big as possible.
i would want the bigger cam, but im 19 and buying valvesprings and the extra money to take care of it might not suit me either
as far as the drivability, that makes no difference to me.
if i misunderstood you, then my bad
. give futral a call and tell them what you are looking for, they will set you up with what you need. i agree. i have it in my car now and put down 351/350 with in on stock exhaust. before the swap i put down 316/343. the guy that did the pulls didn't even know that there was a cam in my car until i told him.
. give futral a call and tell them what you are looking for, they will set you up with what you need.nah, ls6 cam kit comes with springs.. tis cheap too is what i was saying.. ls1 springs barely support a ls1 camshaft.
oh i dunno if this applys but i do want a split pattern.. like 218/222 or something.. or like i said if this is a waste of time and thinking i may go with the 233/239, i just know if i ride around with that cam, ill be a marked man.. ppl around here can stand it when someone gets a new mod.. everyone will want to talk **** and fight from what ive seen, but not even race.
plus im just not sure i can afford the extra stuff needed with much larger cams right now.
i bought a set of manley springs in ti retainers to use with this cam. i think 918's will work with it also. imo, the cam is like the LS6 cam on roids. i think you would be happy with it.
now where do they sale it??? is pushrods 918's and the cam sufficent? i would prolly get a ls6 pump and ls2 timing chain for the swap. i guess thats all still a lil cheaper then dual springs and the stuff needed for a bigger cam.
anyone running the 208/230? or is everyone just going with the 207/220? either way an unusual line of cams.
Predator Z sprays his MTI Stealth II with very good results. That cam makes good power NA also.
http://www.ls2.com/forums/showthread...hreadid=142901
