LS1 to a LS6 Conversion
I was thinking of getting one, what are your impressions of it? Numbers?
Thanks.
Thanks.
Thanks.
May be ok for awhile. The springs will for sure not be an install and forget type of thing.
I went through this with a few C4 Vettes and the LT4 hotcam kit. That kit didn't deter anyone, the buyer was always thought it was a big bonus because it was basically a more refined stock engine. I also had a C4 with an aftermarket high lift cam, nobody wanted it. "I have to check the springs for damage and wear every winter? Bye..."
Aftermarket cam packages are a great thing, as long as you won't be selling the car, IMO. LS1Tech is a great resource, but it represents the lunatic fringe of LS1 owners, not the average buyer.
I feel that anytime the engine has been "cracked open" then you're taking a risk. In some cases it's less of a risk than others but a risk just the same. If you use common sense and you know the engines been torn into you then have to ask yourself - why did he make these modifications.....and you know the honest answer is alway to go faster
Thanks.
There's a reason that most GM performance cams have smaller lift and long seat duration (even when the .050 duration is decent), it's very easy on the valvetrain and lasts a long time, way longer than an agressive aftermarket valvetrain. Duration at .050 has nothing to do with how agressive a cam is, a 224 will usually be harder on the valvetrain than a 244 given the same lift because the ramps are longer on the bigger cam, so the valvetrain accelerations are reduced.
