CC 224/224 116-118 lsa possible w/ TEA 1.5 heads and stock pistons?
I'm purchasing the TEA 1.5s and was thinking of getting the Comp Cams 224/224 but with a wider lobe seperation. I want a smoother idle than their 114* cam and more emissions friendliness. Am I going to have piston to valve issues?
Thanks.
Thanks.
I have TEA S2 5.3 heads with a 226/226,585 +4 degrees ground in and a 116 lsa that will be in next week.
I'll let you know then.
Yes , but be sure to check just to make sure.
In my case i required shorter then stock push rods.
