Lingenfelter GT2-3 LS1 Camshaft and Valve Spring Kit
torque increas will be minimal imo. i only gained 7 tp after i installed the GT2-3. horsepower, on the other hand, will jump about 30 rwhp (i gained 35 rwhp). don't expect a big jump in tq.
Originally Posted by MY99TAWS6
Which is better and why .The gt 2-3 or the new gt7?for turbo application??.
I was set on the gt2-3 because it's gonna be great for me while I"m NA for a year and still be an awesome turbo cam when I switch over.
Closed ex-Sponsor Account
The GT7 is a new grind that replaced the GT2-3 in our turbo applications. Here are the specs: 208/230 .554/.546 121
This cam will give you better performance when you go to the turbo, but I don't think it will work quiet as well in your N/A setup in the meantime.
I think the GT2-3 is the best choice for what your plans are, and I agree with the post above that you will see very good HP gains, but tq gains will be minimal. I definitly don't think you will lose any tq. going to that cam.
Here's a link to all of our LPE LS1 cam grinds:
http://www.lingenfelter.com/lingenfe...24&pf%5Fid=102
Hope this helps,
Ed
Hope this helps,
Ed
Hope this helps,
Ed
Hope this helps,
Ed
Originally Posted by jrp
im wondering what lobes they are; Comps (xe-r/xe), cam motion, crane, ect. it was mostly directed toward Ed, but if anyone else knows they can chime in.
Has anybody heard this LPE cam in person? How loud is the valvetrain noise? I have a Comp 220/224 XER cam that I was planning to install this winter, but I just got to hear another LS1 with an XER grind in it, and the noise was way too much for me. Is the LPE cam much quieter? I'm concerned about the large lift.
#32
I have this cam in my car at the moment but I'm pulling it out in the next few weeks hopefully. Its a great cam and made 31rwph and 1rwt. I had to laugh when we dynoed it and saw the 1 rwt increase. Great stealth cam and the street manners are as good if not better than stock. Installing a F10 cam since my car is no longer a everyday driver. I'm prolly gonna miss it after I change out cams
#33
#34
Originally Posted by Dustin 98TA
I believe its a XE-R grind, I will find out for sure tomorrow, I had this cam for a while. I still have the cam card at the house. Its definately a Comp grind.
The valvetrain noise is noticable, but it also depends on the springs you run with it.The Comp 918's make a little noise, like a sewing machine. What springs were on the one you heard?
The car I heard had Patriot heads/springs. It was way too loud for me. Are duals usually louder than the beehive springs? It looks like LPE is selling this cam along with LS6 springs as a combo, so that may be a better option. I'd just be worried about heavy stainless valves with those springs.
#35
Comp Cams does all of our custom grinds for us, but they don't list our grinds in their catalog, we are the only source for the LPE/LS1 grinds.
The GT2-3 with the LS6 springs is a very reliable, and quiet combination, which shouldn't produce any additional valvetrain noise.
Hope this helps,
Ed
#36
Hope this helps,
Ed
Hope this helps,
Ed
I'm also curious about the valve length issue. Since the LS6 valves are longer than normal, wouldn't that reduce the lift that the LS6 springs can accomodate with a shorter LS1 valve? This sounds like a great combo, and I'm going to install it if I can resolve my questions. Thanks for the info!
#37
I'm so excited about this cam. I'm really looking forward to getting it. With the Rear mounted turbo and a cam that makes my idle smooth. The car will look and sound like a lot less hp that it really will have.
I figure if it gives 30hp over stock I'll probably still gain 15 HP over my hotcam.
#38
SN95 Director
Hope this helps,
Ed
Hope this helps,
Ed
#39
thanks Ed. whats the advertise duration?
Flareside, we've used this combo wit LS1, LS6 and aftermarket 2.02/1.57 valves and not seen any issues with valve float, you are correct that the shorter LS1 valve decreases the amount of lift the springs can handle, but it's not an issue in this combination.
This is a tried and true setup we've used fopr several years. Car Craft magazine did a dyno test with this same setup on a 5.3 with very similar results.
Ed
