Solid Roller vs. Hydraulic
I'll weigh my Morel Lifters when they come in. FWIW you can get a good set of T&D shaft mounts in the $800 Range.
Floyd.
Floyd.
Thanks, Floyd.
What are you going to be using for Cylinder Heads? Intake? I'd look at a set of LS6 or AFR's ported by a really good porter. Meaux, Greg Good, Richard @ West Coast.
The combo I'm putting together is simple but it has to work together to be right.
90 MM LSX intake and TB
Meaux LS6 Heads Set up for Solid Roller
Custom Camshaft
Morel Lifters (would get Jessel's if I had the extra coin $$$$)
T&D Rockers (would get Jessel's if I had the extra coin)
Stock Cubic Inch Forged Rods & Pistons
Custom Camshaft
For heads and intake, was thinking AFR and FAST with the FAST computer for ignition and injection. Still thinking pump-gas, which is 91 octane here in Reno and California.
What are your targets for RPM, torque, BHP and compression ratio?
Thanks again!
JRP on this board is running ~12.02 compression and planning on cali pump gas.
Thanks, I will look around on the net for the contact infos for those guys and PM you if I don't find them. This is going to be a blast!
I am of the opinion that Desktop Dyno sucks. There are a few very good dyno simulation software programs that are very accurate to real world results. These softward programs are far and few between, and VERY expensive.
Ummm, sounds like a big budget. I would also give Katech a call. It sounds like you should be buying the engine complete from an engine builder. And I think for the same price all will use a lot of cubes and fewer revs. Since it is the same block, crank, rods, etc...it is about the same weight.
There is no real reason to use production car parts other than price. With an open budget you would be looking at a Callies/Crower/Cola/etc ctank, Pauter/Crower/Carillo Ti billet rods, CP/JE pistons, etc. Shafts from T&D or Jesel. Ti valves from Del West or Ferrea. Valve springs from PSI. I like the Manley ICD retainers.
Anyway, a given engine builder will have a preference on all this stuff. All of the stuff--crank, rods, pistons, cam, valves--will be built to order. And if they build winning motors that last, that's what counts.
If it is a non-A/C track car, then you should be using a dry sump. Available from ARE (drysump.com).
My 3rd ¢.
David
My 3rd ¢.
David
I have a friend that has only worked on Corvettes since 1975. Vettes are his life. He has offered to help me build the engine. He builds a couple a year for his personal project cars and a couple a month for his corvette customers.
I have been reading forums and books (about 10 now) for the last few months and hope that I can contribute to the assembly process...as well as suggest logical choices for dependable components to reach the power goals. I know there is no replacement for actual experience, so I would not try to build this myself. Besides, it would require an investment in engine-building tools as well.
Big budget...well, sort of big, I guess. Of course, big is relative. I have seen engines for $50k+. Way too much for this kid. I am thinking sub-$20k for the engine with dry sump. Probably Callies/C&A/Carillo/Jesel are in there for sure. That ARE drysump looks very interesting. Will research that more. Was going with Moroso. Not clear on the valves/springs yet. So, I appreciate the pointers to Dana West, Ferrea, PSI and Manley. I will check them out.
When I have my list together, I will post it and see what folks think about the combo.
Dave, thanks for the extra penny's worth. What would you come up with for a dime?
