LS6 / LS1 Valve Spring Questions
I dont own a LS1 or a LS6, but a L67 (blown grand prix). I'm looking to do rockers on my heads and had a few questions about the LS6 / LS1 Springs since they happen to be a perfect match for my L67.
GM Part # 12586484
That is a LS6 Spring with 90lbs at 1.8" install height. Coil bind height is 1.190" and outside diameter is 1.290"/1.060" and inside diameter is .885"/.656" And the spring is in a beehive shape correct?
What are the differnces between a factory LS1 and a factory LS6 spring? Differnt material it is made out of ? But are the diameters of the LS1 and LS6 valve spring the same?
Will Crane Cams Retainers (#144832) work with factory LS1/LS6 GM springs?
Thanks for all the help!
GM Part # 12586484
do you mean "Installed load is 90 pounds at 1.800", 115 pounds at 1.720", and 300 pounds at 1.230"."
Also what are the differnces between
GM # 12586484 and GM # 12565313
76lbs @ 1.800
220lbs @ 1.320
an 01 ls6 spring is
90lbs @ 1.800
260lbs @ 1.320
an 02 ls6 spring is
90lbs @ 1.800
294lbs @ 1.320
thats the data from GM i have anyway. never been good at part #'s as gm changes them all the time. i know 01 springs are blue and i believe 02's are yellow or green.
