torque specs.????
Old Jan 26, 2005 | 11:25 PM
CATCH ME's Avatar
Default torque specs.????
i have a set of non-adjustable jesel shaft mount rockers and wanted to know what are the torqure specs on the bolts. they are goin to be bolted on saturday...help! also what is the best most cost effective torque wrench out there
Old Jan 27, 2005 | 01:25 AM
jrp's Avatar
jrp
SN95 Director
straight from my instructions:
BOLT STAND TO HEAD MAKING SURE THE
JESEL LOGO AND PART NUMBER IS FACING
THE VALVE SPRINGS. THE 1” STAND BOLTS
GET TORQUED TO 22 TO 24 LBS-FT AND SHOULD
BE INSTALLED WITH OIL ON THE THREADS. IF A
BOLT PROTRUDES THROUGH THE INTAKE PORT,
SUPPLEMENT OIL ON THE THREADS WITH RTV
SEALER TO PREVENT VACUUM LEAKS FROM
POSSIBLY OCCURRING.
LUBRICATE PUSHROD TIPS AND INSTALL
ROCKERS AND SHAFTS ON STANDS MAKING
SURE THE CAM’S ON ITS BASE CIRCLE (THE
LOBES ARE NOT OPENING THE VALVES).
NEVER INSTALL OR REMOVE THE ROCKERS
AND SHAFTS WHEN SPRING PRESSURE IS
PRESENT OR SHAFT DAMAGE MAY OCCUR.
TORQUE CENTER 3/8” SHAFT BOLTS TO
45 TO 48 LBS-FT AND THE OUTER 5/16”
SHAFT BOLTS TO 26-28 LBS-FT WITH OIL.
Old Jan 27, 2005 | 02:55 PM
Bill Bowling's Avatar
Talking
Harbor Freight has one for about $20. I have a couple from them and they work great.
Bill
