Highest N/A RWHP?
Old Jan 27, 2005 | 04:11 PM
LT4-398's Avatar
Default Highest N/A RWHP?
Hey guys,
Is there somewhere that you can go to find a listing of the RWHP dyno proved numbers for an all natural LS1/LS6 set up. What are the highest numbers you guys are seeing from the different set ups like stock displacement, 383, 408, and 427. I am looking for all motor numbers. I am building a stout iron block 408 with a very strong heads and cam package and am trying to figure out what kind of numbers to expect.
Ported LS6 intake and throttle body, 11.8 compression, 42# injectors, cam is bigger than 250/250 with more than .600 lift so I'll leave that out right now. 1-7/8 Kooks headers, and a 6 speed behind it all.
Thank you for your input.
God Bless,
Keith
Old Jan 27, 2005 | 04:15 PM
matt346ls1's Avatar
Originally Posted by LT4-398
Hey guys,
God Bless,
Keith
600 plus NA here
Matt
Old Jan 27, 2005 | 04:16 PM
jrp's Avatar
jrp
SN95 Director
there was a thread in the dyno section a while back on the highest dynoing n/a setup. highest 346-348 with a hyd. cam is jasons 505rwhp. Vince used to or still does have the highest dynoing 408; ~550rwhp hp.
Old Jan 27, 2005 | 04:17 PM
mikey's Avatar
LS1TECH Sponsor
Kieth, we made 502/437 with a pump gas 346. I have a pump gas 402 LS2 going together now that will be impressive to say the least. I am with you on the N/A thingy. My car runs mid 9's N/A and will always be an N/A warrior.
Mike
Old Jan 27, 2005 | 04:25 PM
Big-DEN's Avatar
Isn't there a C5R based motor doing 680rwhp@7400 RPM? Its 434 CI,
Old Jan 27, 2005 | 04:55 PM
kp's Avatar
kp
11.6:1, 414cid solid roller with '853' LS1 heads, 1 7/8 QTP headers with HVH collectors/bullet mufflers through a TH400, 8" converter, 9' ford w/4.10s and 28" slicks.
Not the highest but not bad for the compression and using LS1 heads.
Old Jan 27, 2005 | 05:15 PM
Race Car Driver's Avatar
11 & 7 Second Clubs
1344 fwhp n/a (see sig)
Seriously, there's another recent thread on the topic and max hp for an n/a LS1/LS6 motor (non-C5R) of any cid was around 600 rwhp.
Old Jan 27, 2005 | 06:24 PM
Futral's Avatar
Lets not leave out a solid roller 346-348! 550 rwhp\446 rwtq in a M6.
There are several NON C5R 600+ rwhp setups now in a M6,and close to it with auto's.
Old Jan 27, 2005 | 07:11 PM
VINCE's Avatar
Shorty Director
There are some pretty stout setups out there currently. The best my 408ci made NA was 564rwhp/518rwtq in my old Camaro SS thru 3.73's. Swapped to a C5 and changed headers and cam and ended up with 555rwhp/520rwtq. I think the C5's drivetrain robs a little horsepower, but I cant tell. Some locally keep saying my car is maxed out, but they have no clue. Allan wanted to do a lot more.
Old Jan 27, 2005 | 08:18 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
We make 503 with a hyd. roller stock cubic inch motor also in a Z06 which has a bit more parasitic loss in the driveline than an F-Body.
Of course Lou made 54x/48x with his WC car with a big cam and AFRs....
Old Jan 27, 2005 | 09:11 PM
LT4-398's Avatar
Thanks guys,
Thats great news. I am hoping for anything over 500 rwhp at this point. Hopefully more but that will have to be seen.
Keith
Old Jan 28, 2005 | 05:43 AM
VINCE's Avatar
Shorty Director
Thanks guys,
Keith
Not all big motors are built the same. Keep that in mind.
