Dirt in cylinders
Old Jan 27, 2005 | 06:51 PM
Michael Ozorowsky's Avatar
Default Dirt in cylinders
I am about to start buttoning car back up. If there is any sand/radiator coolant or whatever in there when I fire car up will that hurt anything? Just curious how meticulous I need to be on cleaning process. Thanks.
Old Jan 27, 2005 | 06:52 PM
WS-Sick's Avatar
I advise you to clean them.
Old Jan 27, 2005 | 07:03 PM
Brent02's Avatar
Shop Vac
Old Jan 27, 2005 | 07:26 PM
I will clean everything just curious if there is one GRAIN of sand left, will that hurt anything.
Old Jan 27, 2005 | 10:03 PM
CharlieLed's Avatar
Unless the GRAIN is wedged between the piston and the cylinder wall, it will be out the exhaust soon after you fire it up...
Carbon deposits regularly build up on the pistons and get dislodged without causing damage...but like was said previously, clean out all you can now before you button it up just to be on the safe side.
Old Jan 27, 2005 | 10:04 PM
ok, sounds good thank you everyone.
