Engine theory and flame travel
This question pretty much pertains to all engines.
If I'm shooting for a little lower compression ratio on a blown 454, would it be more to my advantage to use a flat top cylinder with a larger cc head, or use a smaller cc head and a dish piston. How does it affect the flame travel and performance of the motor.
What are the pros and cons of each method.
I could also post this in the forced induction board if that would help.
Thanks
Nate
Thanks
Nate
Originally Posted by fast98
i think the small cc head and the dish piston, it will keep quench tight and it will center the flame front on the piston rather then how the cc is shaped.
