How many DIY'ers degree cam?
9 Second Club NA
Im getting ready to intsall my T-ReX. Clearance was .080" on the intake and .060" on the exhuast. Of course, my cam wasnt ground to the exact advertised specs. I was told by one of the saleman from Thunder that the cams arent always going to be ground exact, but they have to fall in a certain range for them to be sold. He also said that all cams are cam doctored before putting on the shelf for sale. I went with a heat treated double roller timing chain from Rollmaster and a bunch of other goodies. Knowing that clearance is tight, should I degree my T-ReX in?
Restricted User
Drag- Its always the safe route, you eliminate the possibility of having an Off-Grind (manufacturer defect etc). Back in the day more people degreed cams to get more torque or more hp, depending on their goal more so than to get ideal clearance... even now, many of us running aftermarket cams are doing what, trying to get every last Hp out. So it makes sense to degree it anyway.
6600 rpm clutch dump of death Administrator
I think its a mistake not to degree a cam. Folks ASSUME that comp, lunati, cam motion, and reed never make mistakes. Do a search and you'll find out that is 100% incorrect. Then folks ASSUME that if the cam maker makes a mistake, then the shop that sold them the cam will have checked it. Again, another assumption. So, many folks are running such tight clearances as it is, and skimping on flycutting, and when you ask them if they degree the cam you get "Nope I just installed it straight up". What if the LSA is wrong? What if its the wrong lobe? What if its just totally the wrong cam?
I'm glad everyone out there just assumes this is all magic, and it goes together like tinkertoys, and it always works. But of course, the same thing goes for springs. Folks install springs and never check setup height or spring pressure either. Then they break a spring, and all of the sudden vendor X makes a crappy spring. Of course the fact that they were .100 off on install height, and the spring have insufficent open/close pressure is ignored since it was never checked....
Bottom line folks assume far too much, and leave too much to chance. When it goes wrong they look to blame the vendors/mfgs for their own mistakes... If you don't check your work, no one else is going to either...
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I just installed a comp cams single chain adjustable sprocket set, very nice piece and allows advance and retard up to 6 degrees with a essentric on the cam sprocket. By drilling, tapping and installing a plug in the recess on the timing chain cover you can adjust the cam timing without pulling anything apart.
9 Second Club NA
I thought the main reason for cam doctoring a cam was to ensure that it was ground properly or to fall in a certain range. Again, my cam wasnt ground to the exact advertised specs, but I assume it feel in the range of being sold. I also thought that degreeing a cam was to verify if the cam is ground properly. So basically youre doing the same thing wether its on a machine or in the car. I would assume that since its been verified on a cam doctor, then to install it straight up. Im not arguing or saying that any of you are wrong, Im just wanting to know myself so that I dont screw anything up. I installed my last cam straight up without verifying anything, but the cam was small and Im sure I had room for error. I must of done it right because it pushed me to the 10s cam only. I cant expect to have great luck this time around, but if my cam has been cam doctored to ensure that its safe to run and has been verified, then should it be re-checked?
On checking the spring height and pressure, I didnt do that either on my last springs, but this swap is much more serious and aggressive. Im installing the Patriot Gold dual spring kit, there are no variances in spring seats, it only comes with 1 size. So the height and pressure is going to be the same right? Again, this swap I feel is more critical, so I want to check everything. How do I check the pressure and height of the springs? Is it necessary on the Patriot kit?
LS1swapper
I thought about doing the same mod to a stock timing cover. Do you have any pics to share? How many holes are needed to loosen the cam bolts? TIA
Originally Posted by nuzee
LS1swapper
Just a newby from downunder, but thought this was also worth a read.
http://www.compcams.com/Technical/In.../Files/145.pdf
Catch
Catch
sorta OT,
I remember reading a couple of years ago about breaking in cams and rockers. They get a memory to them and the entire cam system(cam, rockers, pushrods, and springs) will perform better if you replace the entire system.
not certain if it is true but I was wondering anyways
