So Im walking around autozone.....
Old Feb 3, 2005 | 09:10 AM
RevGTO's Avatar
Pontiacerator
Originally Posted by 01 B4C
Which chain store sells these filters over the counter?
Advance Auto carries the K&N and O'Reilly's carries Wix.
Old Feb 3, 2005 | 09:46 AM
MrDude_1's Avatar
heh, autozone and advance (parts america stores) dont carry wix
i spent $50+ on fluids lastnight..
4.99/bottle for mobile 1 (5 quarts)
4.99/bottle for mobile 1 syn ATF (4 quarts)
+ some change for AC delco filter... i really wanted to stick a wix on there, but the only local store that has them is Parks auto parts (local) and they were closed.
Old Feb 3, 2005 | 11:25 AM
OdinsRage's Avatar
wix is a FAR better value than K&N... K&N is no better than a bosch IMO, same ol' champion filter. Napa Gold is the same filter.
Wix has awesome ADBV, bypass valve, strong spiral center tube with huge holes, awesome construction.
Old Feb 3, 2005 | 02:36 PM
Muffracing's Avatar
Auto Value sells the Wix box. Napa Gold is a Wix and so are the Carquest.
Wix #51522
Napa #1522
Carquest #85522
Old Feb 3, 2005 | 03:46 PM
crainholio's Avatar
Originally Posted by OdinsRage
fram IS junk but...
True statement.
a higher oil pressure means MORE restriction... Remember starting your car in the very cold and the pressure is SKY HIGH!
True statements. How is this related to Fram being junk?
imagine a car with like 2-3psi of oil pressure. Maybe an old 70's ford pickupv8 with bazillion miles. The car has no oil pressure because the bearings and tolerances are so wide there is no backpressure to the oil pump.. its hard to keep those wide open spaces filled with oil!
True.
Basically I'm not getting your point. Fram is junk, yup. Pressure is resistance to flow, yup. Cold oil is thicker than hot oil, yup. Worn out bearings generate less resistance to flow, yup. All true statement, but I don't get the point.
Old Feb 3, 2005 | 03:50 PM
MrDude_1's Avatar
i think hes just happy noone is pro-fram and spouting whatever oil info is in his head, while simultaneously fishing for some pro-fram person to get in a debate with.
do i get a cookie for being right?
Old Feb 3, 2005 | 03:51 PM
MrDude_1's Avatar
also, i get the impression from your reply that you're also fishing............
Old Feb 3, 2005 | 04:14 PM
crainholio's Avatar
No cookie on this one, I just couldn't figure out what he was getting to and there may be valuable info in there somewhere.
Old Feb 3, 2005 | 04:45 PM
blackbird007's Avatar
ok went back to autozone and picked up a mobil 1 #206 filter. This is the longer truck filter that will work right? Also this may be a dumb question, but what is the shelf life of oil, cuz by chance they had exactly 6 quarts of GC 0w30 left and they were on sale so I picked those up too. So that gives me a total of 13 quarts that I now have. Will the left over quarts still be good when it is time to change the oil again? thanks
Old Feb 3, 2005 | 10:15 PM
SSPEEDY's Avatar
Since all the 0w30 Castrol will be made in Germany from now on I doubt you'll have to stock up.
Old Feb 4, 2005 | 08:28 AM
GuitsBoy's Avatar
Where did you get this information from? The very latest castrol 0w30 is being made in the USA, to the german specs. Its the same formula, and that same familliar green color. Ive heard nothing about a switch to 0w30 being exclusively imported from germany. If its not too much trouble, would you be kind enough to link us to your sources.
Thanks,
-T
Old Feb 4, 2005 | 08:28 PM
  #32
Camaro99SS's Avatar
I run M1 0W40, but plan on trying out the German Syntec next oil change since everyone says it's so good.
Jason
Old Feb 5, 2005 | 02:52 AM
  #33
fronzo's Avatar
I run AMSOIL everyhting in all my rides. It's 5.49 a quart but well worth it IMO. I use a K&N long filter, and change every 5000k in my 95 intrepid (what i'm driving now for winter). Its slightley modded, has 162,000 on the clock and runs better than it did when it was new. People cant beleive it has as many miles as it does.
Old Feb 5, 2005 | 09:44 AM
  #34
ccsanders01's Avatar
the fram filters are junk, i had worked for BIG-A autoparts for five years, and the filter rep cut filters apart to show us the insides the fram had alot of cardboard,very cheap looking bypass valve, chinsey spring, and more cardboard, the wix filter is a far better filter
Old Feb 5, 2005 | 10:55 AM
  #35
Matt D's Avatar
Retired Street Racer
Wix #51522
Napa #1522
Carquest #85522
is that the part number for the long wix for 6 quarts, or the stock size?
Old Feb 5, 2005 | 12:31 PM
  #36
Bill Bowling's Avatar
Talking
I just bought Castrol 0w30 at AutoZone for $3.99 each. They also had the 0w30 made in USA. I heard it is the same but bought all the Germany made they had in stock (8qts) for now.
Bill
