lost 37rwhp with head/cam
Opening an exhaust port to the gasket is a major no no....I'm assuming you have a complete round exhaust outlet. Basically the the short turn "floor" of the exh. port was just destroyed and your larger exhaust port now flows less air than it did before it was opened up (certainly a good chance of that anyway).
Also, anyone that would take that approach on the exhaust port might have "handicapped" your intake port as well. You probably have larger heads that flow less air.....the complete OPPOSITE of the desired results. Flow and cc the heads....The results of that test should be interesting.
Good luck...
Tony M.
Mike Norris
