LS1 to LS6
Old Feb 4, 2005 | 01:54 PM
Hennytime's Avatar
Default LS1 to LS6
HYPOTHETICALLY: what exactly would I need to convert my 2002 z28 LS1 to 405hp LS6 spec?
Old Feb 4, 2005 | 01:59 PM
Velocity's Avatar
Sorry, but wrong forum, use search, and this conversion would be a waste of time and money
Old Feb 4, 2005 | 02:00 PM
Zero30's Avatar
hey whats up henny as a matter of fact i just did a swap to an ls6 on my 30th anniversary trans am its pretty straight foward except with the intake also i bought the engine and no harness or computer because i reused mine. However my engine began to misfire. But after a little trip to MTI in houston in runs perfect after they tuned it with ls1 edit so if u dont buy the computer your are going to have to get it tuned...hope that helps.
Old Feb 4, 2005 | 02:07 PM
Zero30's Avatar
velocity is right in respect that i did cost me an arm and a leg
Old Feb 4, 2005 | 02:15 PM
Velocity's Avatar
Yeah... WWWWWWWWWAAAAAAAAAAYYYYYYYY too much money and effort for only a 50 HP gain...
Old Feb 4, 2005 | 02:18 PM
Zero30's Avatar
yeah it cost me 500 bucks to get it tuned in 40 minutes that hurt alot
Old Feb 4, 2005 | 02:30 PM
Vertigo's Avatar
humor me ..what would have to be done to accomplish this? I'm under the impression that the LS6 is an LS1 with a bigger cam and better port to port bay venting and maybe some better flowing heads? I could be very wrong but fill me in on this on guys. THX!
Old Feb 4, 2005 | 02:39 PM
Velocity's Avatar
LS6 comrpession is 10.5:1
LS1 compression is 10.1:1
LS6 does indeed have a hotter cam, and better flowing heads. It also has a better intake manifold than pre-01 LS1s (01+ LS1s used the LS6 intake manifold).
The LS6 block is also scored for some ventilation purposes at higher RPMs.
So basically, a true conversion would replace just about every part of the motor. Now that's silly for 50 HP, isn't it?
Old Feb 4, 2005 | 02:53 PM
abadss's Avatar
^yeah i woudl say so. there are much easier, cheaper ways to get a few extra hp from your LS1. do an LS6 intake swap, Long tubes, and a cam swap, and you have all of the power of the LS6 if not more. for a lot less money.
Old Feb 4, 2005 | 03:10 PM
Hennytime's Avatar
i was just curious, thanks for the replies, i honestly think im going the route of spray, but the idea just dawned upon me...thanks!
