LS2 vs LS6 heads. Are they the same?
Old Feb 6, 2005 | 07:45 PM
MNR-0's Avatar
Default LS2 vs LS6 heads. Are they the same?
The casting # for LS6 is 243. The casting # for LS2 heads is 317. Are they infact different heads? How? Are their flow characteristics identical? If I bolt-on an LS2 head is it the same as bolting on an LS6 head?
Old Feb 6, 2005 | 08:10 PM
crainholio's Avatar
Yes. Chamber, intake ports, exhaust ports. No. No (valves are hollow on the LS6 assemblies).
Old Feb 6, 2005 | 08:13 PM
VINCE's Avatar
Shorty Director
Casting # is 317?? I thought those were the castings for the 6.0L heads?
Old Feb 6, 2005 | 08:25 PM
MNR-0's Avatar
I dont quite follow your answers. Please confirm:
Yes - they are different heads
No they are not similar specs - they have different flow characteristics due to different port intake and exhaust volumes plus chamber volumes
Is there a link someone can guide me to for exact specs on each, incl. CFM?
Old Feb 6, 2005 | 09:10 PM
VINCE's Avatar
Shorty Director
Are LS2 heads old 6.0L heads? I just checked my casting #'s and they are 317's. I have 6.0L heads.
Old Feb 6, 2005 | 09:39 PM
Louis's Avatar
The LS2 heads on the C6 Im looking at have 243 on them
Old Feb 6, 2005 | 09:42 PM
2k2blkss's Avatar
The casting of the LS2 heads are indeed 243. They are identical to the ls6 heads EXCEPT for the valves. EVERYTHING else is the same.
Old Feb 6, 2005 | 09:46 PM
VINCE's Avatar
Shorty Director
I am glad that is cleared up. The C6 has LS6 castings with better valves.
Old Feb 6, 2005 | 10:18 PM
MNR-0's Avatar
Hmmm. Then I guess in OZ we lucked out with the VZ Monaro and you guys luck out with the '05 GTO as they both have #317 castings - based off the Vortec6000?
The C6 must be a different piece of kit even though the '05 GTO is classified the same - aka. LS2.
Good to know as I have tentatively secured a set of #317 castings that are off the LS2 here in OZ. Unless they are as good as the #243 I will have to keep looking.
Old Feb 6, 2005 | 10:25 PM
SPRSPT's Avatar
The C6 has LS6 castings but Not as good of a valve...The Zo6 has the hollow valves...(Less weight)
Old Feb 7, 2005 | 06:00 AM
VINCE's Avatar
Shorty Director
Ahh.. Thanks for clearing that up.
Old Feb 7, 2005 | 08:48 AM
GTO_Scott's Avatar
The two 2005 GTOs at the dealer had 243 casting heads.
Old Feb 7, 2005 | 08:53 AM
93Polo's Avatar
01 Z06s did not have the hollow valves 02+ did
Old Feb 7, 2005 | 09:06 AM
MNR-0's Avatar
Well the LS2 over here is 317 castings. Hmmm. Unless my information is wrong and my workshop doesn't know ****.
OK. Another question. Is the #243 casting better than #317?
Old Feb 7, 2005 | 11:10 AM
93Polo's Avatar
I thought the 317 and 243 were very close. The 243 has a smaller chamber.
