230*@ .050-114 l/c pass smog?
Originally Posted by jrp
tr224 114
i've got a smog sheet on my lap top that shows it passed cleanly.
Originally Posted by slow ride
It comes back around to TR224. The first that was recommend. I guess I will just get some AFR 205's and the Tr224 and be done with it? I guess I have been trying to squeak somthing a tad bigger in there.I didnt want the same ol TR224. What about one of them ECD is that right? cams like you got.
but yes you could have him grind you a smog grind. the tr224 114 works great though as an OTS cam and i've got smog sheets verifying its passing ability. not a friend of a friend who's uncles brother passed with so and so cam. if you want to play it safe stick with what works.
lol i've got over 15* overlap with my EDC, by no means smog legal
yet to be determined.
Slow ride, I went through a lot of this same questioning you did to find a cam with AFR 205 heads that would pass smog. Like you, I wanted to try something just a tad bigger than the 224/224, but I couldn't find anyone who had done it. I also talked to many sponsors, several who said I could pass a cam 226/232, 224/230, 228/228, etc.. easy with the right tune. (Some even went so far as to say they had never heard of a cam in this size range NOT passing, which puzzled me - though I could never find any stats to back this, nor could they produce any to prove it - nor would they offer to try and tune for me, and being that it would have to be a mail tune, I don't blame them). Not to say you can't, but if anyone has, they aren't revealing their secret.
So I settled on the 224/224 581/581 114 XER cam. I still have to run through emissions though.
What's the right tune in terms of LTRIMs and timing ? What else can you affect if you're still in closed loop ? I've heard one trick is to retard timing a lot so that cats will heat much above normal but don't know if it really works. That kind of tune is definately for smogging event only...
You should be able to get by. I passed a sniffer locally (using CAT's) in WA State on the rollers and at idle with the Cartek 3X camwhich is rumored to be a low/mid 230's duration camshaft...of course I had to do some tweaking to get it by :>)
