6.0L Heads
Old Feb 10, 2005 | 11:05 AM
Ed Blown Vert's Avatar
Default 6.0L Heads
I finally got my heads from Absolute. But they are bare with only valves.
I will need to order a spring kit, rocker arms, studs, bolts and gaskets.
Couple q's
1. Can I just buy and use stock rockers and studs on these heads?
2. Anything else I need to buy?
I am thinking about just selling these and buy some fully assembled heads and not deal with this.
Heads
Old Feb 10, 2005 | 12:05 PM
technical's Avatar
It's really not a headache at all.
I would use the stock rockers unless you have some money you needed to get rid of. You still have the stock rocker bars/locators?
Then I'd buy the Patriot Gold springs. I don't know if the springs come in a kit with locks and retainers, but you'll want them. Get the Ti retainers.
Then make sure you have the correct length pushrods.
Old Feb 10, 2005 | 12:36 PM
I don't have any of the valvetrain except for the valves.
That is why was thinking about buying another set of heads.
I am guessing I will be spending another $500-800 to complete these. But I can spend another $800 and get a fully assembled set. :dunno:
Then sell this set.
Old Feb 10, 2005 | 12:46 PM
technical's Avatar
Even an assembled set doesn't come with the rockers and rails...
You're going to pay just about the same for the springs and retainers on the assembled set minus a few bucks.
Are you replacing the heads on your current ride? or is this a new buildup?
Old Feb 10, 2005 | 12:53 PM
You know you are right. I am just so flustered with Jay.
So I can just pull them off of my current set of 5.3L heads and use them?
I am replacing my 5.3L with 6.0L
Thanks for the help.
Old Feb 10, 2005 | 01:02 PM
2001 Pewter WS6's Avatar
Restricted User
Yes, you just need springs, retainers and locks. Use the rockers that are currently on your motor now.
Old Feb 10, 2005 | 01:06 PM
Thanks guys, I imagine I can also reuse the stock pushrods.
Old Feb 10, 2005 | 01:11 PM
technical's Avatar
Check the preload, but there's a good chance they'll be just fine.
Old Feb 10, 2005 | 01:21 PM
Thanks guys
Old Feb 22, 2005 | 10:06 PM
Just got them flowed. 315 @ .550
Shop has me worried. Said that that too much material was removed and velocity at low rpms might suffer.
Old Feb 22, 2005 | 10:10 PM
Bo White's Avatar
Yeah, to get big #s like that you have to remove a pretty good amount of material. As long as the low/mid #s are good you should be fine.
Old Feb 22, 2005 | 10:16 PM
I'll have the shop fax over the sheet and see what they are. Thanks.
Old Feb 22, 2005 | 10:21 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I had a 230/236 cam and ran Y/T rockers, Comp 7.400 pushrods, and Crane 893 double springs.
I have a set of used 893's if you are hurting, I would just get them checked.
Old Feb 22, 2005 | 10:28 PM
2c5s's Avatar
What kind of bench, bore size and pressure were used to flow?
Old Feb 22, 2005 | 10:32 PM
BrentB@TEA's Avatar
Couple q's
Heads
Ed, it is not a problem at all we have spring sets in stock as well as keepers. If you want we can also assemble for a small fee. BTW 315 @ .550 is a good number. I would not be to worried. You should be good if they are going on a 4 inch bore engine.
BTW springs,titanium retainers,cups and seals are 289.00 (PRC Kit) keepers are about 20.00 and we do not charge for shims. It shouldn't be hard to have them set up locally to you either. Just get around 140 on the seat (you will lose 10 psi after first heat cycle) and you should be good to go. (about 1.78 install height)
Brent
Old Feb 22, 2005 | 11:25 PM
TVWilkes's Avatar
I think Brent made a typo, the spring kits are $289.00
Old Feb 22, 2005 | 11:29 PM
Not sure on the specs with the bench, but I will ask.
I have already ordered my spring kit. The heads should be complete hopefully in about 2 weeks. I am going to also have them CCed.
I don't mind spending the money. Just not twice.
Thanks alot guys.
Old Feb 23, 2005 | 06:24 AM
BrentB@TEA's Avatar
I shouldn't type in my sleep!
Old Feb 23, 2005 | 08:47 PM
2c5s's Avatar
Ed, you gonna post the flow sheets?
Old Feb 23, 2005 | 09:03 PM
ktmrider's Avatar
Glad to hear you got the heads ( finally )! You have the patience of Job IMO.
Can't remember what motor you have, just keep in mind the flow rates when choosing a cam. It shouldn't affect ya too much.
