Need some opinions??
Old Feb 11, 2005 | 03:13 PM
TN94Z's Avatar
Default Need some opinions??
I am going to buy some new parts for the car. My question is, which do you think I should go with. Heads and cam package(heads are complete AFR's) or cam, nx maf kit, and suspension. This is assuming that I am getting a good deal on the heads and cam package. I am looking to get in the 6's in the 1/8. I can't make my mind up and I am looking for your opinions. Thanks in advance
Old Feb 11, 2005 | 08:45 PM
Ragtop 99's Avatar
the cheapest way to go fast is to spray it. H&C are nice for a daily driver; the power is always there. In either case to get into the 6's you'll need some good rubber, so make you budget $$ for slicks.
Old Feb 12, 2005 | 07:47 PM
TN94Z's Avatar
I already have the slicks...so that is not a problem
Old Feb 12, 2005 | 07:51 PM
LSUxBlake's Avatar
I sprayed my LT1 and didn't really like it because you didn't have the power all the time. I have heads/cam on my LS1 and love it. Power all the time without having to refill a bottle.
Old Feb 12, 2005 | 08:32 PM
TheBowtieboy's Avatar
Well, my opinion has always been - make sure you can control what you have (power wise) ......that would lead you to upgrading the suspension.
But, since you've mentioned that the 1/4 mile is your desire, while suspension is important, at the "base" level you're better off with the heads/cam and tune route.
Old Feb 13, 2005 | 09:30 AM
TN94Z's Avatar
Well, 1/8 mile is the only track we have close, but it will see the 1/4 quite a few times. Suspension was my next mod, but I have run up on this deal with the heads and cam that is a great deal. I figure that I should get in on this while I have the money and then I can piece together the suspension a little at a time. With slicks and stock suspension, do you think it would get some descent 60ft's with the heads and cam? I know that it won't be spectacular or anything, but if I can get descent 60ft's with the head/cam package, then that is probably what I will do.
Old Feb 13, 2005 | 02:33 PM
LSUxBlake's Avatar
Lower control arms with relocation bracketrs are the most effective suspension parts for your 60 foot. Get a set, you'll really notice a difference.
Old Feb 13, 2005 | 03:55 PM
LSonederfull's Avatar
Really? What is your 60ft. before and after brackets?
Old Feb 16, 2005 | 06:48 PM
Question
TTT ?
