Iron block prep?
Old Feb 13, 2005 | 12:15 PM
HAMRHEAD's Avatar
Default Iron block prep?
I plan on getting an iron 6.0L block and having a crank, pistons, rods all installed and was wondering what I should have done to the block itself (machining and what not)? The block will be a brand new block. The motor will be set up with forged internals and will be FI later on when I get more money. any help is appreciated. Any suggestions of options will help too.
Old Feb 13, 2005 | 12:46 PM
derek_silvy's Avatar
Where are you getting the block from?
How much was it for just the bare block.
Old Feb 13, 2005 | 12:53 PM
FungusMungus05's Avatar
I'd like to know as well I just took delivery in of a brand new 6 Litre Iron Block
and would like to know of any combos that you guys are running note it will be street/strip but mostly street not a daily driver...................
I'm hoping of atleast and please correct me if im way off I want to achieve Horses (700+) on juice.............................
what crank size are you guys running to get 408 cubes?
and any benefits of a solid roller cam if I go 400+ cubes...
Old Feb 13, 2005 | 04:23 PM
HAMRHEAD's Avatar
I'm thinking of getting a block from TSP. I will be eventually be running FI on it so I want to build it up with forged parts. Do you need to have these blocks machined before installing the internals? I would assume at least checked for proper tolerances.
Old Feb 14, 2005 | 12:09 AM
HAMRHEAD's Avatar
No suggestions or advice?
Old Feb 14, 2005 | 12:38 AM
goober35's Avatar
The only thing i can sujest is to get a BMR K member and when you get the block u will have to drill and tap for on of the alternater bolts.
Old Feb 14, 2005 | 07:31 AM
StickSS's Avatar
HI: I would take the new block to a machine shop and have them double check the cylinder bores for out of round and taper to make sure it is correct. Also I would have them check the deck heigth of the block. It may have to be surfaced. Also I would have them install Main Studs and aling hone the main bearing saddles. I think the cam bearings come installed all ready from the factory on new blocks so you don't have to worry about that. I would just feel safer having the block checked out before putting it together. Good Luck
