F13 safe with nitrous?
Old Feb 13, 2005 | 03:22 PM
freakynipples69's Avatar
Default F13 safe with nitrous?
Is it safe to run a F13 cam with a 100 dry shot?
Old Feb 13, 2005 | 03:36 PM
PREDATOR-Z's Avatar
if well tuned and with ample fuel supply, of course.
Old Feb 13, 2005 | 03:44 PM
I am gonna change the topic a bit. I am finally getting that badly needed 12bolt. Should I go with a cam/100 dry shot setup, or a heads/cam setup? I figured I could easily reach close to 500rwhp with the cam/nitrous setup but I am not sure what kind of gains I would get with a heads/cam setup. I will most likely be switching from the TR224 to a F13, heard too many good things about it.
My car is strictly a street car, very very little track time.
Old Feb 13, 2005 | 10:30 PM
PREDATOR-Z's Avatar
I wouldn't even bother with the FM13 if you allready have a tr224. You'll find that the tr224 has the FM13 under the curve (which is what you want on the street) and with a 125>150 shot you will be over 500rwhp. I made over that with a stock cam and 200 dry.
Old Feb 13, 2005 | 10:57 PM
nspr8td lt1's Avatar
just jet up on the cam you have now, instead of spending the extra $$ on a new cam, make sure you have all the necessary parts (warmer, purge, window switch, fpss.)
goodluck
Old Feb 13, 2005 | 11:20 PM
Damian's Avatar
LSX Mechanic
There is NOTHING, absolutely NOTHING "unsafe" about running ANY cam with nitrous. Others will have better results, but there isn't a cam on the planet that will contradict nitrous and cause harm to a motor.
That being said, your fuel pressure, timing, and A/F tuning will be the key. The Fm13 will most certainly kick *** on nitrous
Old Feb 14, 2005 | 01:26 AM
MUSTANGEATER's Avatar
I agree
You can bottle anything...
Old Feb 14, 2005 | 09:26 AM
Well it looks like its the TR224 cam with a 100shot then! Can't wait for this summer
