LS1 to LS6 Conversion
Old Feb 16, 2005 | 10:51 PM
Fast331's Avatar
Question LS1 to LS6 Conversion
Any of you guys done this conversion. i have heard that all same equipment, just different setup. better rwhp? Any problems with this swap? just curious, might want to attempt if job is fairly easy, just wondering
thanks fast331
Old Feb 16, 2005 | 11:00 PM
00ls1's Avatar
Possible Scammer - Buyer Beware - Issues Unresolved
different block, heads, valvetrain, pcv, and intake. thats all
Old Feb 16, 2005 | 11:17 PM
01_SuperSlow's Avatar
There are a lot better options out there than just an LS6 conversion. Do a search, there is a wealth of info here.
Old Feb 16, 2005 | 11:23 PM
BlueSix's Avatar
If you're gonna take the time and money to do the LS6 conversion just go all out and do heads and cam. Won't cost a whole lot more and you'll see MUCH better gains.
Old Feb 17, 2005 | 12:03 AM
93TAWicked1's Avatar
Yep LS6's are peices of crap!
Old Feb 17, 2005 | 12:23 AM
Robert56's Avatar
I agree, they only run high 11's bone stock.
Old Feb 17, 2005 | 12:59 AM
fast01's Avatar
There are better options power wise, but I swapped in an LS6 long block from GM Performance Parts because water doesn't compress when it enters the lower front ram air on your LS1 because your favorite local covenience store fails to keep the drainage system in the parking lot clear and you end up in over a foot of water causing a piston to shatter into many pieces and twist a connecting rod into an "S" shape. Yeah, that was a run-on rant, but said local convenience store was found to be responsible for the damage so all the parts had to come from GM and appear to be stock (they paid for them). The engine was swapped and with nothing more than a tune (you'll need one) it's running in the mid to low 12's. Very easy and I'm very happy. Gas mileage wasn't affected either!
Old Feb 17, 2005 | 01:07 AM
Zach@Texas-Speed's Avatar
do heads and cam....voila....you have even better than an LS6!!
Old Feb 17, 2005 | 07:55 AM
Bill's 02 Z-28 SS's Avatar
Hi Folks
if you want low risk approach, go with the LS6 (GM ported heads and Cam). I have not Dyno'ed my car as of this posting but I have been told I should see around 400+ RWHP. Yes there are better cams but it is a function on what you are looking for.
Bill
Old Feb 17, 2005 | 09:11 AM
GTO_Scott's Avatar
I had planned on going the 2004 LS6 head and cam route (405hp setup) but decided to try AFR heads instead. I have a brand new set of heads in box and new cam in tube and would sell it below dealer cost if someone was interested. That would be about half the price of doing AFR and custom cam.
