Magic Stick 3 base circle? Needed pushrod length?
Old Feb 18, 2005 | 07:19 PM
RX-Ben's Avatar
Default Magic Stick 3 base circle? Needed pushrod length?
I'm looking for confirmation on my measurement of the base circle of the TSP MS3 cam- I got a base circle that is a whopping .13015" smaller than stock.
Can anyone confirm this?
With a head shaved .040" and a headgasket @ .040" thickness, I've calculated that I'll need 7.366" pushrods (assuming a stock length of 7.380").
Thanks
Ben
Old Feb 19, 2005 | 08:07 AM
RX-Ben's Avatar
I think I went in the wrong direction- the base circle is smaller than the amount shaved so I need to ADD the difference to the length of the stock pushrods. Sound correct?
Here is the math:
base circle = .13015" smaller
.065075" smaller radius
head is .052" closer vs. stock. It is shaved .040" and headgasket is .012" closer vs. stock headgasket
.065075" (smaller base circle) - .052" (distance moved closer to cam) = .013075" longer pushrod needed
7.8000 (stock pushrod length) + .013075" (to make up difference between base circle and new rocker height) = 7.813075" (new pushrod length)
It looks like a need 7.8125" pushrods?
Thanks
Ben
Thanks
Ben
Old Feb 19, 2005 | 08:45 AM
LS198TA's Avatar
stock pushrods are 7.400 i have milled heads and im running comp cams 7350s
Old Feb 19, 2005 | 10:19 AM
RX-Ben's Avatar
I've heard that, but I've also heard that they are 7.380
https://ls1tech.com/forums/showthrea...pushrod+length
Thanks
Ben
Old Feb 19, 2005 | 02:42 PM
luv2spd's Avatar
Yeah stock is shorter than 7.4 thats why most people get 7.4 w/ aftermarket cams to account for the smaller base cirlce. This is with umilled heads though.
Old Feb 19, 2005 | 03:17 PM
BADFNZ's Avatar
Here is the math:
Thanks
Ben
I still don't see where you're getting 7.800 from.
If stock is 7.38 and you need to add .013, you'd need a 7.393. You should be OK with a 7.400 since the hydraulic lifters compensate a bit for the added length.
Old Feb 19, 2005 | 03:27 PM
RX-Ben's Avatar
Hmm...I have no idea where I pulled 7.8 from. In any case, 7.38 is what I meant to put there. 7.4s sound good to me too.
Ben
Old Feb 20, 2005 | 08:39 AM
PREDATOR-Z's Avatar
This is what you need:
From Thunderracing
Old Feb 20, 2005 | 09:25 AM
fast98's Avatar
from what u have up there i calculated 7.393 but go get a pushrod length checker like above
Old Feb 20, 2005 | 09:37 AM
muraoka's Avatar
Ben
7.8 is stock length for gen1 blocks. the easiest way to check length is to get an adjustable pushrod. assemble the rockerarm and adjust the pushrod till the rocker is centered on the valve stem. pull out the pushrod and measure it.
matt
Old Feb 20, 2005 | 09:49 AM
RX-Ben's Avatar
I have 2 lifters that leaked down (they are completely soft) and the others are still pumped up (very hard, I can't squeeze them by hand). Can I use the "hard" ones with the adjustable pushrod?
Thanks
Ben
matt
Old Feb 21, 2005 | 08:07 PM
fastsspr's Avatar
yes you can do it.
Old Feb 22, 2005 | 09:20 AM
RX-Ben's Avatar
Thanks guys. I already have the adjustable push rod, I'm just waiting for my modded LS1 rockers to come back from Harland Sharp. The bearing mod has taken over a month for them to do.
Ben
