ticking noise at about 25% throttle
Old Feb 18, 2005 | 10:35 PM
nitetrain_02ws6's Avatar
Default ticking noise at about 25% throttle
hey guys got a question ive got a top end ticking noise at about 25% throttle its a used motor that hold about 10 lbs of oil pressure at idle but jumps up to about 50 or 60 lbs under acceleration what do you guys lifter, rocker, cam maybe something else any advice is appriciated thanks
Old Feb 18, 2005 | 11:44 PM
Cal's Avatar
Cal
Does it tick at cam speed or crank speed? Does the tick depend on engine load at all? Check for bent push rods, this is easy to do.
Old Feb 18, 2005 | 11:57 PM
Crazy Man's Avatar
Mine did the same thing was running 10-15psi at idle and ticking about 25% throttle. Ended up being a rod bearing but it sounded like it was coming from the valve train. First i would check for exhaust leaks, then tighten all sprk plugs, run some seafoam in the oil, check that all rockers are tight, Check pushrods by rolling on flat surface, pull heads check or replace lifters, If none of that helps its probly a spun rod bearing.
Old Feb 19, 2005 | 08:24 AM
thanks guys you told me exactly what i didnt want to hear but i guess its time for a 427
Old Feb 19, 2005 | 08:49 AM
Another_User's Avatar
Are you running a stock air pump? There are also lots of normal things that tick that may not mean disaster too.
Old Feb 19, 2005 | 12:46 PM
yes im running a stock air pump. but it really spounds like its coming from the valve train. im going to tear it down one day this week is there any way to remove the lifters without pulling the heads can you just remove the intake and the plate under the intake then pull the push tubes and remove the lifters
