what valvetrain kit with g5x3?
Old Feb 20, 2005 | 06:46 PM
getlifted's Avatar
Bad Seller Alert
Default what valvetrain kit with g5x3?
99 ls1 with stock heads. Which valvetrain setup with the g5x3 cam only. What do i need to swap off of the stock heads and what head gaskets? Thanks for any help.
P.S. also have a tsp 231/237 cam for sale. $250 shipped
Old Feb 20, 2005 | 07:50 PM
LS1Maniac's Avatar
You don't need to take the heads off. I would go with patriot dual valve springs and whatever brand hardened seats and retainers you want as well as some hardened pushrods. That's all you really need other than the tools to do the actual swap.
Old Feb 20, 2005 | 09:13 PM
01_SuperSlow's Avatar
Get yourself a PRC spring kit or a Patriot spring kit. Make sure you change the valve seals. The PRC kit includes the seals, not sure on the Patriots. What you need to swap out of the stock heads is springs, spring seats, retainers, and valve seals.
Old Feb 20, 2005 | 10:38 PM
getlifted's Avatar
Bad Seller Alert
Thanks for the info.
Old Feb 20, 2005 | 10:40 PM
getlifted's Avatar
Bad Seller Alert
any write ups on doing a spring swap? Thanks again.
Old Feb 20, 2005 | 10:56 PM
Orange Peel's Avatar
I went with the Comp Cams 921 kit, been working great and that's what LG recommends.
Old Feb 20, 2005 | 11:28 PM
LS1Maniac's Avatar
http://www.ls1howto.com/index.php?article=23
Old Feb 21, 2005 | 12:18 AM
DVST8OR's Avatar
